Noob Question: turbo s2000
Old Nov 7, 2004 | 08:01 AM
BigC-ivic's Avatar
Default Noob Question: turbo s2000
So yesterday I had the chance to have a ride in a 425whp S2000... it was fun and scary
my question is.... when we were racing up through the gears, as the rpms rise, there is a sound like air swirling... is that sound the turbo or is it air being let out of the wastegate?
Old Nov 7, 2004 | 08:05 AM
PrettyLude's Avatar
turbo spinning
Old Nov 7, 2004 | 08:19 AM
swlabhot's Avatar
Default Re: (PrettyLude)
Ahhhh..... the sweeet sweet sound of the snail spoolin up. There is no sound quite like it
Old Nov 7, 2004 | 09:45 AM
BigC-ivic's Avatar
Default Re: Noob Question: turbo s2000 (BigC-ivic)
do wastegates make any kind of sound?
Old Nov 7, 2004 | 10:03 AM
msmotorsports's Avatar
Yes they do. It is similar to a fluttering soud. Under heavy boost it will sound louder than the turbo when it opens.
Old Nov 7, 2004 | 10:07 AM
BigC-ivic's Avatar
Default Re: Noob Question: turbo s2000 (msmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">Yes they do. It is similar to a fluttering soud. Under heavy boost it will sound louder than the turbo when it opens.</TD></TR></TABLE>
thanks.... I was pretty sure it wasn't the turbo... not sure why
it sounds like air escaping at intervals...
this guy is running over 20lbs of boost
Old Nov 8, 2004 | 02:03 PM
nate951's Avatar
Sounds like you're describing a blow off valve. Did it only happen when he shifted gears?
Old Nov 8, 2004 | 02:13 PM
BigC-ivic's Avatar
Default Re: Noob Question: turbo s2000 (nate951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate951 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you're describing a blow off valve. Did it only happen when he shifted gears? </TD></TR></TABLE>
no no
I know what a blow off valve soudns like... and it was as the RPMs went up, not when shifting
TURKISHFORCE
Feb 23, 2011 07:33 AM
girty
Apr 3, 2007 07:44 AM
yellows2k
Honda S2000
27
Apr 5, 2006 07:40 AM
slow_redcivic
Jan 4, 2006 07:39 PM
intekragsr
Jan 4, 2002 09:09 AM
