wastegate with 8psi spring opens at 13
Old Nov 7, 2004 | 02:12 PM
truesleeper's Avatar
Default wastegate with 8psi spring opens at 13
I have a ss autochrome wastegate with an 8.7psi spring (checked it is colored blue) and it is hooked up to its own vacume tapped into the charge piping right befor the throttle body. My boost guage is running off its own vacuum source from the manifold. The problem is my wastegate will hold a solid 13 psi according to the boost guage and it will not creep and oppens at exactly 13, but it is supposed to hold 8psi..i cant figure out why its not opening at 8 unless my guage is wrong.
Old Nov 7, 2004 | 02:13 PM
slambedcivic's Avatar
Default Re: wastegate with 8psi spring opens at 13 (truesleeper)
you answered your own question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by truesleeper &raquo;</TD></TR><TR><TD CLASS="quote">I have a ss autochrome wastegate </TD></TR></TABLE>
Old Nov 7, 2004 | 02:21 PM
Atheist's Avatar
Default Re: wastegate with 8psi spring opens at 13 (slambedcivic)
Probably true though
Old Nov 7, 2004 | 02:47 PM
JDMs1eeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by truesleeper &raquo;</TD></TR><TR><TD CLASS="quote">I have a ss autochrome wastegate with an 8.7psi spring (checked it is colored blue) and it is hooked up to its own vacume tapped into the charge piping right befor the throttle body. My boost guage is running off its own vacuum source from the manifold. The problem is my wastegate will hold a solid 13 psi according to the boost guage and it will not creep and oppens at exactly 13, but it is supposed to hold 8psi..i cant figure out why its not opening at 8 unless my guage is wrong.</TD></TR></TABLE>
Don't feel bad. I have a 3.8 spring in mine. It opens at 8 and creeps to 10....
Are you running an exhaust on your car? or are you running open down pipe? I think my creeping issue is the lack of back pressure but I dunno why it waits to 8 to open. oh wellz...
Old Nov 7, 2004 | 02:59 PM
Oh i forgot when ssautochrome didnt put the tial logo on their wastegates which are identical they magically lost reliability, damn maybe ill draw my own tial logo on it and it might work right, i am running open down pipe at the moment but i didnt think that would effect it. Maybe im wrong. Ive heard plenty of good results with this wastegate so i dont think it is but if enough people believe the brand is the cause then i will get a new one, im trying to rule out everything else first.
Old Nov 7, 2004 | 03:02 PM
who knows? maybe its just a fluke.
Old Nov 7, 2004 | 03:29 PM
JDMs1eeper's Avatar
hey an exhaust, thats my problem. Nothing is wrong with tah wastegate. Drag kits do the same thing when you run open down pipe. instead of going to 5 they go to 8-9 and creep. Because of lack of backpressure from running no exhaust. Get an Exhaust on and you should be ok. I need to do the same! lol
Old Nov 7, 2004 | 03:37 PM
eg6T's Avatar
Default Re: wastegate with 8psi spring opens at 13 (JDM S1eeper)
would the boost guage and the wastegate get different readings because they are in 2 different spots?
D-meet07
Sep 23, 2019 03:06 AM
boostedf22cd5
Oct 10, 2006 09:30 PM
wildman117
Apr 19, 2006 04:00 PM
mrx
Dec 26, 2005 10:43 AM
Sohc Driver
Jul 20, 2003 11:31 AM
