wideband o2 reading
Old Nov 2, 2004 | 05:49 PM
darkirony's Avatar
Default wideband o2 reading
Hey quick question, i hooked my wideband up and just curious i thought i would be running rich but in actuallity im running around 12.5-12.7. full boost at 5lbs. i want to up it to 7 psi on the revhard kit. is it a good idea or what
Old Nov 2, 2004 | 05:57 PM
dennis's Avatar
Default Re: wideband o2 reading (darkirony)
which is on the richer side of the scale...
Old Nov 2, 2004 | 06:32 PM
xenocron's Avatar
12.5 is not bad for only 5 psi.
as you start upping the boost, bring those AFRs down in the 12-12.2 range up to about 8-9 psi. Over that 11.7-12 to be on the safe side.
Old Nov 2, 2004 | 07:55 PM
gsrt's Avatar
Default Re: wideband o2 reading (xenocron)
what kind of wideband do you use? i would like to get one.
Old Nov 2, 2004 | 09:07 PM
darkirony's Avatar
cool thx for the replys, im running the zeitronix wideband
Old Nov 2, 2004 | 10:10 PM
SOHC_MShue's Avatar
Default Re: (darkirony)
yea just bring it down around 12.1 for 7psi.
Old Nov 3, 2004 | 06:58 AM
darkirony's Avatar
also i didnt retard my timing any should i do that before i up the boost to 7
Old Nov 3, 2004 | 07:30 AM
SOHC_MShue's Avatar
yea you should retard it a little bit. It doesn't need much timing retard from 0-5psi, but after that you should retard a little bit. What are you using for managment?
Old Nov 3, 2004 | 09:55 AM
darkirony's Avatar
Default Re: (SOHC_MShue)
fmu, have the safc hooked up just not tuned yet
TravisBiggie
May 17, 2012 06:43 PM
1990hondaHF
Oct 26, 2010 06:36 AM
R6E6I6D
Dec 10, 2005 10:06 PM
clu
May 23, 2003 06:20 AM
willyboyK20
Oct 30, 2002 09:50 PM
