tial bov spring rate
Old Nov 5, 2004 | 01:40 PM
Machine1's Avatar
Default tial bov spring rate
for those with the tial bov. which spring are you running for your street setup.
i think i have the 11lb spring, and i get some compressor surge on low throttle/boost.
will switching to the lowest (7lb i believe) spring rate effect anything?
Old Nov 5, 2004 | 01:54 PM
J337_UNIT's Avatar
Default Re: tial bov spring rate (Machine1)
i use 7lb spring, no surge at all here, but the BOV is open at idle, it closes upon any increase in throttle tho
Old Nov 5, 2004 | 02:55 PM
whp
Guest
Posts: n/a
i have the 7psi spring too, im going to be upping the boost soon, whats the most psi the tial bov can hold?
and would a 7psi spring still be good if i run 12-13 daily and 19 at the track?
Old Nov 5, 2004 | 05:42 PM
ineedhelp's Avatar
Default Re: (sleevedgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleevedgsr &raquo;</TD></TR><TR><TD CLASS="quote">i have the 7psi spring too, im going to be upping the boost soon, whats the most psi the tial bov can hold?
and would a 7psi spring still be good if i run 12-13 daily and 19 at the track?</TD></TR></TABLE>
would like to know that also.
Old Nov 5, 2004 | 05:49 PM
FOrSfEd's Avatar
Default Re: (ineedhelp)
The 7 pound spring should be good for about 15 or so psi daily. If you were to plan on runninfg more than that I would recommend the higher 11 pound spring.
Old Nov 5, 2004 | 05:54 PM
BoostedEG6's Avatar
I have a friend that is boosting about 26psi (i think or around that amount) with a Tial Bov and he has no problem. I also have this BOV but car isnt running at the moment
Old Nov 5, 2004 | 07:03 PM
Machine1's Avatar
Default Re: (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">I have a friend that is boosting about 26psi (i think or around that amount) with a Tial Bov and he has no problem. I also have this BOV but car isnt running at the moment</TD></TR></TABLE>
what spring rate does he have.
Old Nov 5, 2004 | 07:13 PM
BoostedEG6's Avatar
Default Re: (Machine1)
not to sure but I want to say he is running the 11lbs spring... I will check and find out though
justYncredible
May 15, 2012 01:01 PM
1DayIllBFast
Jul 7, 2009 12:27 PM
didder
Aug 26, 2008 05:50 PM
Nextelbuddy
May 11, 2007 08:42 AM
h22 civic
Jan 30, 2005 12:40 PM
