most ls engine whp
Old Mar 12, 2005 | 07:13 AM
deeweezy187's Avatar
Default most ls engine whp
What is the most whp someone has made on a b18b engine i have searched but haven't found anything and what is you guys setup?
Old Mar 12, 2005 | 07:48 AM
s2kdre's Avatar
Default Re: most ls engine whp (deeweezy187)
500whp on 30psi
Old Mar 12, 2005 | 08:31 AM
shermanyang's Avatar
Default Re: most ls engine whp (jdmhonda)
don't know how much i'll make once i find some more funds to finish my build. right now i'm still at stock bore and 9:1 comp. with stock cams. hopeing for some 402t, propane injection system, 84mm 9.5:1 pistons, itr tb...and 500+ whp on pump gas.
Old Mar 12, 2005 | 09:22 AM
dnbruut's Avatar
Default Re: most ls engine whp (shermanyang)
whats the advantage of propane gas inj.?
thanks
Old Mar 12, 2005 | 11:01 AM
Blue98Ex's Avatar
Default Re: most ls engine whp (dnbruut)
I have a boy running 417whp on an LS with just pistons, rods, and a block guard.
Old Mar 12, 2005 | 01:26 PM
Default Re: most ls engine whp (Blue98Ex)
thanks guys can't wait to start my project
Old Mar 12, 2005 | 01:29 PM
bukbukintegra's Avatar
226 hp @ 196 lb-ft on 7psi - Stock LS
Old Mar 12, 2005 | 01:50 PM
GeeGee's Avatar
This had been discussed to death.
It's now about how much power you make, but how long it will last at that level.
Old Mar 12, 2005 | 02:31 PM
Default Re: most ls engine whp (bukbukintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bukbukintegra &raquo;</TD></TR><TR><TD CLASS="quote">226 hp @ 196 lb-ft on 7psi - Stock LS</TD></TR></TABLE>
had the car for two years... been turboed for a year and a half... motor has nearing 70,000 miles, and been to the majority of the drags in 2004, (2 days out of each month) done well over 50 runs down the track... maintenance will do the car good! hehe
o yea, everything is stock...
Old Mar 12, 2005 | 02:32 PM
Chip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnbruut &raquo;</TD></TR><TR><TD CLASS="quote">whats the advantage of propane gas inj.?
thanks</TD></TR></TABLE>
It allows you to run more boost/timing/compression on pump gas, it's like adding more octane to your motor. Not the best for a turbo setup IMHO. At low boost you want to inject less propane than at higher boost, but nobody makes an adjustable on the fly propane system. Alcohol is much nicer for a turbo IMHO.
Old Mar 12, 2005 | 06:31 PM
miro_gt's Avatar
that's where I would stay for stock motor ... for long last
on my D16Z6 I expect to stay at about 160 WHP (will finish instalation tomorrow)... may go up to 185, but no more that 200 for sure
Old Mar 13, 2005 | 09:29 AM
D-meet07's Avatar
Default Re: most ls engine whp (miro_gt)
The D16Z6 motor stock cant handle no more that 7-8 psi. Go any higher than that then it will blow a head gasket or a ring. Have to remember that its a single cam and the iternals are alot smaller and weaker. The d16z6 is more based of economy drivability
Old Mar 13, 2005 | 09:44 AM
Squirtle's Avatar
WOW! What's the set up on 500 on 30prsi LS?
Old Mar 13, 2005 | 02:11 PM
dnbruut's Avatar
Default Re: most ls engine whp (squirtle)
i know that propane has got a high octane level but because of another burning rate and a hotter burn it doesnt do anything. or do you inj. it liquid?
btw i live in holland. alot of cars drive on pure propane in holland cause of the high fuel prices. it even wracks stock engines! and my teacher used to work as a propane systom developer and he used to work with a racingteam that wanted to try propane for its high octane level. no power gains and they couldnt advance timing with 1degree over 98octane fuel.
let me know if you got any more info on this.
Old Mar 13, 2005 | 02:18 PM
mrDFWmechanic's Avatar
hp all depends on the persons setup
Old Mar 13, 2005 | 03:22 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
i made 293whp and 234ftq @ 14lbs on a stock LS motor.... made over 50 1/4 mile pases best 12.076 @ 116. the oil pump failed on me and now im going to a gsr 500+whp its going to be fun
teg_95
Jul 2, 2008 11:40 PM
crxsteve
Nov 13, 2007 04:36 PM
racer034life
Welding / Fabrication
May 12, 2005 11:32 AM
Lei Siew Long
May 9, 2002 04:54 PM
