oil burning ?
Old Mar 13, 2005 | 07:49 PM
Jradrebel's Avatar
Default oil burning ?
i have a 2000 civic SI turbo... bought it about six months ago.... TTR turbo kit, garret t-4, tial b.o.v, tial wastegate, custom manifold, custom intercooler, vortec FMU, stock internals, besides a lower compression Head gasket... 6psi, un tuned, engine has 33k on it...
just recently its been burning oil.. it was between shifts but now it seems to be steady when boosting.. not ridiculously but noticeable.. i have no idea how to fix or what to do about it.. or is it a problem if i don't fix it.. is it piston Rings going up or turbo or just a normal thing for turbo cars.. id say it looses 1 1/2 quarts every 1000 miles.
lemme kno ur insight ..thanks!
Old Mar 13, 2005 | 07:51 PM
Jradrebel's Avatar
Default Re: oil burning ? (JRadRebel)
well i can't say how bad it burns.. it depends on how much im gettin on it ** edit from statement above
Old Mar 14, 2005 | 09:34 AM
Jradrebel's Avatar
no help bump!
Old Mar 14, 2005 | 09:36 AM
Hyaboosta's Avatar
theres no leaks coming from the return line? because if it's not choking then your sels are prob. bad.
Old Mar 14, 2005 | 09:42 AM
Jradrebel's Avatar
Default Re: oil burning ? (Hyaboosta)
seals in the turbo?
Jradrebel's Avatar
as long as it prob isn't engine related .. rings would be a bad thing
Old Mar 14, 2005 | 09:44 AM
Jradrebel's Avatar
oh and when i say burning oil.. i mean its comming outta the exhaust.. blue smoke
Old Mar 14, 2005 | 10:21 AM
GDM Z28's Avatar
do a comp. check
Old Mar 14, 2005 | 06:56 PM
11SEC CIV's Avatar
compression test or leak down test is your answer--from my exp....most likely piston rings!! ( I always wished it to be valve seals/ never was!!)
Old Mar 15, 2005 | 01:29 PM
Spoolin18's Avatar
Sounds like piston rings if you are smoking a good bit. I live in Frederick, MD about 35 mins from you and i am a mechanic...could take a look at it for you if you wanted..just let me know
Old Mar 15, 2005 | 02:35 PM
non-VTEC's Avatar
i would first pull the downpipe off and inspect the turbo for oil seal leakage.
that could cause constant smoking also........
Old Mar 15, 2005 | 03:44 PM
nonvtecD's Avatar
Where is your valve cover breather going? Any smoke out of it.
Old Mar 15, 2005 | 05:08 PM
Ress887's Avatar
how do u like that manifold??
Old Mar 15, 2005 | 06:12 PM
95cxhatch's Avatar
Default Re: (Ress887)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ress887 &raquo;</TD></TR><TR><TD CLASS="quote">how do u like that manifold??</TD></TR></TABLE>
has a lot to do with his smoking problem
anyway, like has been said...comp test and/or leak tests are your answer to this question.....also a quick look at IC pipes and downpipe will help too, could be a combination of both rings and turbo seals
Old Mar 15, 2005 | 06:15 PM
platinum00's Avatar
Default Re: (95cxhatch)
unhook your downpipe and change pipes. look for oil there. could indicate turbo seals. if not do a comp check.
running around un tuned can easily take out your motor.
good luck
Old Mar 17, 2005 | 12:00 PM
Jradrebel's Avatar
hey.. i just look at my valve breather.. its a tube that just runs outta the valve cover.. but .. theres oil residue on the end of the tube?.. normal.. or piston rings shot.. but no smoke comes out of it when my engines hot.. no saying it would
Old Mar 17, 2005 | 04:55 PM
95cxhatch's Avatar
if there is actual oil residue in your breather and/or smoke coming out, it is a good sign of blow-by, meaning bad rings ussually
is there a PCV catchcan set up or anything on the engine to help release crankcase pressures?
Old Mar 17, 2005 | 08:11 PM
StockBlockRob's Avatar
Default Re: oil burning ? (95cxhatch)
bring that **** to kyles and we will do a compression test. Didn't we tell you we would help you with this **** when you bought that car?
Old Mar 19, 2005 | 11:03 PM
Jradrebel's Avatar
UPDATE = COMP TEST = TURBO GOIN UP NOT PISTON RINGS
overrev_it
Mar 27, 2009 06:54 AM
91crxracer
Aug 21, 2006 08:14 AM
hoggy
Jul 21, 2004 08:06 PM
Tinker219
Jul 6, 2004 02:29 PM
napester21
Aug 20, 2003 10:18 PM
