What Else Is there...
Old Mar 12, 2005 | 01:48 PM
LSEGHATCH's Avatar
Default What Else Is there...
What electronics do I need for my setup to complete? I have boost and air/fuel gauges, hondata s200b, tach, .......I can't think of what other things I will need such as VAFC, more gauges, etc....
Tyler
Old Mar 12, 2005 | 01:53 PM
GeeGee's Avatar
if you already have hondata, I wouldn't waste money on a VAFC. However, you could invest in EGT, oil level..ect.
Old Mar 12, 2005 | 02:03 PM
Dunc's Avatar
BCICAN
Default Re: (Krabbypro)
If you have a hondata:
1.) Do not get a VAFC
2.) Do not get an MSD rev limiter/boost retard system (get a regular ignition)
3.) Do not get the "common" narrow-band A/F gauge. Get one, but make sure it is a <U>wideband</U> such as the AEM UEGO or the DynoJet Commander
4.) Gauges: You can get as many as you want, but a few important ones are: Water Temp, Boost, Wideband A/F, Oil Pressure, Oil Temp, EGT, Fuel Pressure....from there its basically what ever gauge you want after that.
Old Mar 12, 2005 | 02:48 PM
LSEGHATCH's Avatar
Default Re: (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">If you have a hondata:
4.) Gauges: You can get as many as you want, but a few important ones are: Water Temp, Boost, Wideband A/F, Oil Pressure, Oil Temp, EGT, Fuel Pressure....from there its basically what ever gauge you want after that.</TD></TR></TABLE>
Sounds good so.. the autometer air/fuel gauge I have now is pretty much useless? Where might a good place be to find a wideband and which is most reccomended (don't wanna skimp out in anyway possible). Also I am unfamiliar with the "EGT" Gauge, if I am not mistaken, that's an abbrev. for..?
Thanks For Posting
Old Mar 13, 2005 | 09:59 AM
Dunc's Avatar
BCICAN
Default Re: (LSEGHATCH)
As for monitoring an accurate A/F reading your current one isn't too useful. I would say go to AEM's website and then DynoJet's website and read up about their wideband sensors. It is mainly which one you like....alot of people have used the AEM one, but I have heard good things about both of them. I just bought the dynojet, but I can't tell you how it is just yet becaue it just came in yesterday. EGT just stands of Exhaust Gas Temperature. It is fairly important, but nescessarily a must have right now type thing.
Old Mar 13, 2005 | 10:31 AM
pissedoffsol's Avatar
25 Year Member
Default Re: (Dunc)
PLX makes a good wideband... http://www.plxdevices.com
wideband, EGT, oil pressure, boost are the 4 must haves IMO. everything else is optional.
Old Mar 13, 2005 | 02:15 PM
ProjectDarkBlack's Avatar
Default Re: (pissedoffsol)
is it easy to see detonation with an EGT?
Old Mar 13, 2005 | 02:42 PM
LSEGHATCH's Avatar
Default Re: (ProjectDarkBlack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack &raquo;</TD></TR><TR><TD CLASS="quote">is it easy to see detonation with an EGT?</TD></TR></TABLE>
Good question I would like to know as well....
Old Mar 13, 2005 | 03:32 PM
Dunc's Avatar
BCICAN
My guess would be no. Seeing as detonation is a quick occurance and an EGT isn't exactly the quickest in response. By the time anything changed on the EGT, I would say it'd be <U>way</U> too late.
Old Mar 13, 2005 | 05:17 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">PLX makes a good wideband... http://www.plxdevices.com
wideband, EGT, oil pressure, boost are the 4 must haves IMO. everything else is optional.</TD></TR></TABLE>
Drkaccrd
Jul 14, 2005 01:58 PM
ludetech
Jun 24, 2004 04:24 PM
SIowner
May 3, 2004 08:49 AM
Forrest Gump 9
Apr 27, 2004 09:18 PM
Rah Rah
Jan 3, 2003 07:41 PM
