ZEX
Old Mar 13, 2005 | 03:05 PM
d16rice's Avatar
Default ZEX
I bough a used ZEX kit, but it had no instructions.
It’s a dry kit rated at 35-75 shot.
What jets should I use to max it (75shots).
I also noticed that there’s a place for a jet where the fuel psi regulator connects, what goes there?
I tried looking at ZEX website, but had no luck, my computer’s not displaying that page.
Old Mar 14, 2005 | 03:50 AM
d16rice's Avatar
Default Re: ZEX (d16rice)
Oh come on, someone, pleeeeese.
Old Mar 14, 2005 | 06:17 AM
freezerburnv2's Avatar
I had a Dry Zex kit for my D16y7 pretty much comes down to this, if you haven't added any fuel supply upgrades then 55 is great, go in there with a good FPR bump it up a bit then 75 shot will work out. Don't spray longer than 8 seconds or you will be rebuilding that motor in no time. a good 14 pound bottle should last you about 3 mins that's 180 seconds divide by 8 equals 22 and half runs. only thing I had wired up was the nitrous in then a line to the intake. wires for power then wire for TPS sensor should be it, It's been a while I sold my nitrous kit for a LS motor. You will avg about $30 per bottle refill. if your burning up a good bottle a week might want to get turbo kit save some money in the long run. Good to have a Air Fuel Ratio gauge to watch if you start running lean. change your oil often and try to get hold of some colder running spark plugs and RETARD YOUR TIMING. by the way here is the pdf file for installation.
http://www.zex.com/Technical/I...s.pdf
Happy Spraying and don't forget to fill up on premium!!
Old Mar 14, 2005 | 06:32 AM
Default Re: ZEX (freezerburnv2)
another thing DO NOT GET platinum spark plugs, avoid them all the way! almost forgot that those things can be trouble. Hope I didn't forget anything. Nitrous is addicting if your burning a whole bottle in a weekend your burning too much.
Old Mar 14, 2005 | 09:31 AM
d16rice's Avatar
Thanks for the help and the web page, but do you have the Tune-up sheet for the kit.
The instructions on the web-page don’t tell me what jets go where and what the power ratings are.
Some of the things I altered on my engine to accommodate the N2O kit are,
Bigger injectors
Adjustable fuel PSI regulator
MSD 6A ignition (iridium IX spark plugs)
And a few other minor changes.
Old Mar 15, 2005 | 04:10 PM
d16rice's Avatar
pleeeeeezzz, Tune-up sheet.. ...anyone?
Old Mar 15, 2005 | 04:16 PM
DaX's Avatar
DaX
Loved
Community Favorite
What size injectors? Stock ECU? Put your OEM injectors back in...the Zex kit is designed to work with them and if you're running larger injectors on a stock ECU, you'll run rich as hell.
Old Mar 15, 2005 | 04:20 PM
d16rice's Avatar
Default Re: (DaX)
Well, mines a mini-me, D16Y7 block and Y8 head
The injectors are off of Y8 (they're better flowing), but I'm also using P2P ecu, instead of P2E, so I should be fine.
As for the fuel psi regulator, it has a gauge on it, and is currently set on stock pressure. I also have an Air/Fuel ratio gage, so I can tune it if need be.
Old Mar 16, 2005 | 03:27 AM
d16rice's Avatar
Default Re: (d16rice)
Tune-up, tune-up, tune-up...... ....sheet.........
Old Mar 16, 2005 | 06:35 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16rice &raquo;</TD></TR><TR><TD CLASS="quote">Well, mines a mini-me, D16Y7 block and Y8 head
You'll probably be ok with the Y8 injectors, since you're using an appropriate ECU. You won't be able to tune anything with your AFR gauge...assiming you're using a stock narrowband sensor and the gauge does not give actual AFR values.
Old Mar 16, 2005 | 09:58 AM
d16rice's Avatar
Default Re: (DaX)
I meant I could use the fuel PSI gauge and A/F ratio gauge as reference and tune the motor using the adjustable fuel PSI regulator and adjustable cam-gear.
Old Mar 16, 2005 | 01:48 PM
d16rice's Avatar
Still waiting to see if any one has a tune-up sheet for the ZEX kit.
Old Mar 16, 2005 | 01:58 PM
wantboost's Avatar
Who is Mr Robot?
what the **** is a tune up sheet&gt;?
Old Mar 16, 2005 | 02:09 PM
d16rice's Avatar
Default Re: (wantboost)
It's a sheet that comes with a kit and tells you waht jects go where and what hp gains can be expected with a certain setup.
Old Mar 16, 2005 | 02:29 PM
RyanEJ8's Avatar
I got it at home. I'll post up the correct jettings for 55, 65, and 75 shots when I get home from work tonight.
Old Mar 16, 2005 | 07:18 PM
d16rice's Avatar
Default Re: (RyanCivic2000)
thanks
Old Mar 17, 2005 | 08:39 AM
RyanEJ8's Avatar
Sorry didn't get a chance to get online last night. I promise I'll have the chart's info for you tonight.
Old Mar 17, 2005 | 07:15 PM
d16rice's Avatar
Any luck yet?
Old Mar 18, 2005 | 04:44 AM
d16rice's Avatar
Plese, someone?
Old Mar 20, 2005 | 02:11 PM
d16rice's Avatar
Still looking for the tune-up sheet for a Dry ZEX kit
Old Mar 21, 2005 | 05:32 AM
d16rice's Avatar
Please, someone, just post the sheet, that's all I'm asking.
Old Mar 21, 2005 | 06:27 AM
RyanEJ8's Avatar
Sorry this is so late, been extremely busy lately.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">ZEX Nitrous Kit #82011 Tune-Up Sheet
Horsepower/Nitrous Jet/Fuel Jet/Recommended ignition retard
55hp/32/36/0
65hp/35/34/2
75hp/38/32/4
Premium quality fuel, 92 R/M octane or better, is required at all times for safe operation of yhour ZEX Nitrous System.</TD></TR></TABLE>
Old Mar 22, 2005 | 05:14 AM
d16rice's Avatar
Thank you, I really appreciate your help.
jmicus123
Apr 5, 2010 07:08 AM
eg six
May 29, 2006 05:45 PM
BlackRocket
Oct 9, 2004 07:48 AM
MooreBoost
Feb 18, 2004 10:18 AM
v-tec crx
13
Dec 26, 2001 06:19 AM
