Ignition Setup what to chose?
Old Mar 11, 2005 | 06:47 AM
YashiMotors's Avatar
Default Ignition Setup what to chose?
Hi! I need help with choosing a good and cheap setup for ignition. I will be running a B16A1 built motor stock sleeves with 14-18 PSi remapped with chipped ECU.
What type of ignition system, external coil, sparkplugwires, plugs exc should I choose? What's nesesary? Whats good, whats bad?
Have searched alot but didn't find the answears I needed.
Old Mar 11, 2005 | 07:02 AM
beepy's Avatar
Default Re: Ignition Setup what to chose? (YASH)
The stock dizzy is fine, an external coil may be a good idea. Stay away from CD ignitions. "Racing" wires are more bling than function. The best plugs are NGK BKR7ES-11.
Old Mar 11, 2005 | 07:07 AM
Default Re: Ignition Setup what to chose? (beepy)
i got bosch Platinum Plugs 1 step colder than stock.
yeah the stock Honda coil is very tiny but anybody here that runs 14-16 Psi on stock coil?
Old Mar 11, 2005 | 11:45 AM
PrettyLude's Avatar
get some oem or ngk plug wires
Old Mar 11, 2005 | 02:17 PM
Default Re: (PrettyLude)
so you guys think 14-16 PSi shouldn't be any problems with stock ignition..... than i'll give it a try with new cap, plugs, wires, I will get back after i tuned with the result...
Old Mar 11, 2005 | 02:23 PM
MidShipCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">The stock dizzy is fine, an external coil may be a good idea. Stay away from CD ignitions. "Racing" wires are more bling than function. The best plugs are NGK BKR7ES-11.</TD></TR></TABLE>
There is no best plug, each setup has its own. Magnecor gets down to the point with there wires.
First off, distributor suck thats why honda moved on to cop.
Inaccurate timing. The least intense spark compared to all other ignition systems.
Old Mar 11, 2005 | 02:28 PM
cnydc2's Avatar
Default Re: Ignition Setup what to chose? (MidShipCivic)
I have heard that the MSD digital 6 is a very good ignition for boosted Hondas. Please correct me if I'm wrong b/c I'm looking to get that for my boosted GS-R.
Old Mar 11, 2005 | 03:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">There is no best plug, each setup has its own. Magnecor gets down to the point with there wires.First off, distributor suck thats why honda moved on to cop.Inaccurate timing. The least intense spark compared to all other ignition systems.</TD></TR></TABLE>
yes i know that distrubuter suck ... but since we all dont have a huge budget to spend on our cars, we have to make the best of the situation.
Old Mar 11, 2005 | 09:35 PM
T4eg's Avatar
Default Re: Ignition Setup what to chose? (cnydc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnydc2 &raquo;</TD></TR><TR><TD CLASS="quote">I have heard that the MSD digital 6 is a very good ignition for boosted Hondas. Please correct me if I'm wrong b/c I'm looking to get that for my boosted GS-R. </TD></TR></TABLE>
the digital 6 is a awesome ignition. I was going to use that but got a deal i couldnt pass up on the digital 7plus.
Old Mar 12, 2005 | 06:28 AM
cnydc2's Avatar
Default Re: Ignition Setup what to chose? (BlueHatch00)
I would love the digi 7 but the price is a touch to steep for me right now
Old Mar 12, 2005 | 09:26 AM
DRAGLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote"> Stay away from CD ignitions. </TD></TR></TABLE>
You have somehting to back this up with? Or is it something you HEARD
I have compared both stock ign. and the msd set up their was a nice difference between the two,with the msd car was more responsive and the top end miss dissapeared.
Old Mar 12, 2005 | 12:46 PM
*Boostwerks*'s Avatar
Umm...what?
Everyone I know that makes over 500 HP is running a MSD CD setup. There is one person that comes to mind that got away with just the stock Honda Distro with an SS coil on his 600hp setup.
The best setup IMO right now available, is either the MSD Digital 6, Digital SCI (basically the same thing as the Digi 6, or the Digital 7. Either one combined with the SS or HVC coils will be more than enough too support over 700hp.
And about the plugs...everyones setup is different. It is going to take a lot of testing to find the right plug that will make the most power without misfiring/detonating. There is a huige difference in a 200hp setup running the 11s versus a 600hp setup running 9s. The 600hp setup would definetly be detonating if they were running the 11s.
Mark
Nov 27, 2013 10:08 AM
shythappenz
Apr 6, 2006 11:48 PM
shoebox
Jul 28, 2005 09:54 AM
DarkDragon
Jan 30, 2005 08:33 AM
Nicathug
Oct 24, 2004 08:08 AM
