Which Drag Radial
Old Mar 11, 2005 | 07:05 AM
1SlowSi's Avatar
Default Which Drag Radial
In another post there was a pole between the two from BFG.
G Force and T/A Well what im confused about is that fact that the G-Force is called
G-Force T/A Drag Radial. Which one of the two is the bad *** one everyones talking about?
http://www.tirerack.com/tires/bfg/bfg.jsp
Old Mar 11, 2005 | 07:15 AM
reynosop's Avatar
Default Re: Which Drag Radial (1SlowSi)
BFGoodrich GeForce T/A Drag Radial
Old Mar 11, 2005 | 07:27 AM
1SlowSi's Avatar
Default Re: Which Drag Radial (reynosop)
theres two kinds.
Old Mar 11, 2005 | 07:38 AM
Tchleung's Avatar
get the DR
There is only 2 called Drag Radial..... The rest are jsut performance street tires
Old Mar 11, 2005 | 09:01 AM
1SlowSi's Avatar
Default Re: (Tchleung)
dude, click on the link. You'll see this
g-Force Drag Radial
g-Force Drag Radial 2
The first one looks like what i need.
Old Mar 11, 2005 | 09:03 AM
DIRep972's Avatar
Smarter than you
Default Re: (1SlowSi)
Theres a Comp TA drag radial and a G force drag radial but they might not call the old one a Comp TA anymore. you want this one-
Old Mar 11, 2005 | 09:07 AM
1SlowSi's Avatar
Default Re: (DIRep972)
thanks man. Yeah thats the one that looked right. $112 each. For a 15" SI rim on my 99Si, do you think a 225/50 would fit? If im gonna get these i want the most contact. 205 just aint enough. Or is it? for 400whp
Old Mar 11, 2005 | 09:10 AM
turboEGhatch's Avatar
Neither the 205's or the 225's will hook up perfectly on the street with over 400 WHP, but take your gearing into consideration. The 205 is 23.1" tall, the 225 is 23.9" tall. AFAIK the only difference between the two tires is the tread pattern, they use the same compound.
Old Mar 11, 2005 | 09:12 AM
DIRep972's Avatar
Smarter than you
Default Re: (turboEGhatch)
You might as well go 225 the price is so close. How much does your car weigh? Im assuming you have an Si if so you should hook 400 fine in 3rd/4th and probably in 2nd if ur suspension is decent enough.
Old Mar 11, 2005 | 09:57 AM
1SlowSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboEGhatch &raquo;</TD></TR><TR><TD CLASS="quote">Neither the 205's or the 225's will hook up perfectly on the street with over 400 WHP, but take your gearing into consideration. The 205 is 23.1" tall, the 225 is 23.9" tall. AFAIK the only difference between the two tires is the tread pattern, they use the same compound.</TD></TR></TABLE>
AFAIK? whats that. How will the 23.9" tall affect anything? yeah speedo thats about it. So will the 225's fit on a stock si rim?
Old Mar 11, 2005 | 10:12 AM
Tchleung's Avatar
AFAIK = As fas as I know. C'mon man. gotta get with the l337 talk LOL
Old Mar 11, 2005 | 10:16 AM
1SlowSi's Avatar
im lost as hell on all that man. lol
Old Mar 11, 2005 | 10:20 AM
riceball777's Avatar
theres no way the 225 will fit a stock 6 inche rim
you will need the 205/50/15
Old Mar 11, 2005 | 10:25 AM
FATBOYeg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">How will the 23.9" tall affect anything? yeah speedo thats about it.</TD></TR></TABLE>
a taller tire will change the gearing if that makes any sense. it will give you more mph per gear, which in turn helps traction. i hope i explained it alright.
Old Mar 11, 2005 | 10:26 AM
Finland's Avatar
You are better off getting a race-only set of rims for the front, you should use at least a 7" rim for 225s to keep the sidewall more square.
Old Mar 11, 2005 | 10:42 AM
1SlowSi's Avatar
Default Re: (Boondock Saint)
yeah i was gonna get a set of rims for the front. Whats a good set? Slipstreams???
Old Mar 11, 2005 | 11:03 AM
PM-Performance's Avatar
Default Re: Which Drag Radial (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">theres no way the 225 will fit a stock 6 inche rim
you will need the 205/50/15 </TD></TR></TABLE>
the hell it wont. Ive done it. and so have others
Get the ones pictured above. the older ones suck. I guess they work better for RWD supposedly. but these ones hook pretty hard. If you are pushing 400whp these will still give you a hard time. i blzed mine up a few times on like 350-375
But deff go 225's
Old Mar 11, 2005 | 03:32 PM
99blusi's Avatar
Default Re: Which Drag Radial (itr206)
The 225's fit on my stock Si rims without a problem.
Old Mar 11, 2005 | 06:21 PM
Si Shane's Avatar
Default Re: Which Drag Radial (99blusi)
What kind of rubbing issues do you have with your 225;s? My front tires are smoke and its time to replace. currently i'm on bridgestone 205/50.
99si with coilovers, so i can change the height. I'm due for an alignment anyway.
Old Mar 11, 2005 | 09:33 PM
T4eg's Avatar
I have the 225 50 15's on some blades. And 235/60/14 MH dots on some 14 x 5.5 hx's
Old Mar 11, 2005 | 11:38 PM
*Boostwerks*'s Avatar
So for those of you who drive regularly on the newer BFG's, how many miles have you gotten out of a pair?
Also, how is the handling?
Old Mar 12, 2005 | 03:08 AM
Nikoli's Avatar
Default Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">So for those of you who drive regularly on the newer BFG's, how many miles have you gotten out of a pair?
Also, how is the handling? </TD></TR></TABLE>
wondering the same
Old Mar 12, 2005 | 05:17 AM
1RMDave's Avatar
I drive pretty aggressively and it was my daily driver. I got a month and a haf outta my set. Probly around 4-5000 miles
Old Mar 12, 2005 | 06:41 AM
chihuahuamanx's Avatar
Default Re: (1RMDave)
ad this is in the FI forums becauuuusseee.........?
Old Mar 12, 2005 | 07:07 AM
vtec.dc2's Avatar
i don't daily drive.. mostly when its around track night.. i'd place them one and have them for day or few.. sometimes during fall or spring i may put them on. i lost count of miles driven.. but it should be at least 4-5k on these if not more. i don't do much of spinning, just enough to get the water of
i have 205 on 6". i don't think wider will help without more wheel behind it
