idle up and down after new motor? Whats wrong?
I just put a j-spec d16a6 in my CRX. i have a jackson racing supercharger. i think i have every thing hooked up where it was. But there isnt any vacume leakes. i know that a buddy of mine put a turbo on his car and it did the same thing. Can any one help me, hints, ideas, any thing.
Re: idle up and down after new motor? Whats wrong? (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">Sticking or dirty air control valve. Remove and clean.</TD></TR></TABLE>
where is that located??
Re: idle up and down after new motor? Whats wrong? (kevino002)
sure you dont have any vac leaks.
IAC valve is on your intake manifold, check that like stated above.
Re: idle up and down after new motor? Whats wrong? (dscrxsi20)
Make sure your radiator is blead. If there are any air pockets it can cause a fluctuating idle.
Re: idle up and down after new motor? Whats wrong? (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">sure you dont have any vac leaks.
IAC valve is on your intake manifold, check that like stated above.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCarp »</TD></TR><TR><TD CLASS="quote">Make sure your radiator is blead. If there are any air pockets it can cause a fluctuating idle.</TD></TR></TABLE>
and also the fitv
and also the fitv
Re: idle up and down after new motor? Whats wrong? (PrettyLude)
i had the same problem and the problem was that the throttel linkage was adjusted so that the throttle was open with out pushing gas.
-Toby
-Toby
Well HONDA-TECH you have saved my *** again. i cleaned and adjusted what i think is the idle air control, but what ever you called it, it worked. But there is a problem with running lean when im just at a steady speed. do you have any ideas on this problem. plus what kind of cars you all got.
signed stupid minnesota ricer
I dont have an aftermarket fuel pressure regulator. and i dont know my fuel pressure. but before i swapped out motors i didnt have a problem and i thought it was the same motor. but i dont know.
