Should i boost?
Old Mar 13, 2005 | 11:07 AM
Novtecdohc's Avatar
Default Should i boost?
I was wounding do you think that its safe to boost a LS motor with 186,000 Miles?
It has no knocking,leaking or anything? still runs good.. I was goning to use a Garrett T3 turbo a 6-8psi, what do you think?
Old Mar 13, 2005 | 11:14 AM
Sohc Driver's Avatar
Default Re: Should i boost? (Novtecdohc)
I already told you. Run a compression and leakdown test to know the condition of the motor. If all is good replace the waterpump, timing belt, oil pump, distributor cap, rotor, spark plugs, and plug wires. If you do all of that, you will be good to go.
Khoi
Old Mar 13, 2005 | 11:42 AM
Dunc's Avatar
BCICAN
Default Re: Should i boost? (Sohc Driver)
I agree with sohc driver. Just do some tests on the car and then replace the vital stuff regardless.
Old Mar 13, 2005 | 11:46 AM
''s Avatar
boost that ****! mileage on a honda does not matter. age and its condition does.
Shaynepolevault
Nov 17, 2007 03:43 PM
streetspeed607
Oct 2, 2007 07:31 PM
budget
Apr 1, 2006 01:22 PM
SpoolnByYou
Jan 30, 2006 03:53 PM
DeL SLo
Jan 11, 2003 11:43 AM
