check engine probs when boosting
Old Mar 13, 2005 | 04:12 PM
turbohybridhatch's Avatar
Default check engine probs when boosting
on a 91 crx with b16 swap when boost hits 5psi the check engine lights comes on and reads map sensor, im running a jg edelbrock intake manifold with 99si throttle body and 99 si map, with missing link check valve then i switched to stock crx map via vacum of manifold with in line petra check valves (pet shop special)five of them in line... dont know what else to do any ideas?
Old Mar 13, 2005 | 04:39 PM
y7turbo's Avatar
Default Re: check engine probs when boosting (turbohybridhatch)
maybe the missing link was dirty or defective.. are you sure you installed the pet shop check valves right.. the valves should let the air out of the hose. could it be you need more check valves? i never went that way so im not sure how many you need to make it work.. you could try to call the place you got the missing link from. they might know whats wrong with it..
Old Mar 13, 2005 | 05:03 PM
PrettyLude's Avatar
you sure the missing link is installed the right way?
Old Mar 16, 2005 | 01:08 PM
yea i tryed all that i blew through the check valve and it worked as it was spossed to onlt blows though one way and with the pet shop valves ive used them before on a friends set up he ran 8psi through 5 of them with no probs im trying for 5psi through 5 with no luck.. i was thinking bout putting stock old school t/b back on so map would read through factory vacum port off t/b but i dont see why it would make a differance!!?
Old Mar 16, 2005 | 01:10 PM
Default Re: (PrettyLude)
who is prettylude? im in alexandria i know peeps in laff i go to 410 sometimes
Old Mar 16, 2005 | 01:11 PM
dustin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohybridhatch &raquo;</TD></TR><TR><TD CLASS="quote">yea i tryed all that i blew through the check valve and it worked as it was spossed to onlt blows though one way and with the pet shop valves ive used them before on a friends set up he ran 8psi through 5 of them with no probs im trying for 5psi through 5 with no luck.. i was thinking bout putting stock old school t/b back on so map would read through factory vacum port off t/b but i dont see why it would make a differance!!?</TD></TR></TABLE>
How do you have them hooked up though? They aren't supposed to be inline...
Old Mar 17, 2005 | 07:05 PM
Default Re: check engine probs when boosting (dustin)
no i dont have them inline i have them on t fittings like they should be im not sure what the prob is
Private50
Nov 2, 2003 06:11 PM
crx1856
May 19, 2003 10:44 PM
B17aTrbo
Aug 16, 2002 08:32 AM
Integra_Boi
Aug 11, 2002 07:03 PM
filetofit
Jun 4, 2002 02:56 PM
