F20B Boosted.
Old Mar 14, 2005 | 08:53 AM
CiViC SiR's Avatar
Default F20B Boosted.
hi,
i just want to know how boost will my engine handle since my C/R is 11.0:1, and how much whp should i make?
stock internals
Fidanza flywheel 8.8lbs
clutch master stage 4
440cc injectors
wlabro 255 fuel pump
uberdata
SAFC
turbonatics t3/t04e
VP C16 racing fuel
Old Mar 14, 2005 | 10:25 AM
CiViC SiR's Avatar
Default Re: F20B Boosted. (CiViC SiR)
any help please
Old Mar 14, 2005 | 11:44 AM
Dunc's Avatar
BCICAN
well the 440 injectors are good to about 300whp (max).....as for boost: well 11.0:1 is awfully damn high for forced induction. I would definitely say bring the CR down before boosting your engine.
Old Mar 14, 2005 | 12:11 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiViC SiR &raquo;</TD></TR><TR><TD CLASS="quote">hi,
stock internals
440cc injectors
uberdata
SAFC
turbonatics t3/t04e
VP C16 racing fuel
They really shouldn't be used in the same sentence or on the same car.
As far as boost, with the C17 you can be a little more aggressive with the timing, but still on 11:1, just make sure you are tuned.
Old Mar 15, 2005 | 08:55 AM
CiViC SiR's Avatar
Default Re: F20B Boosted. (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">
As far as boost, with the C17 you can be a little more aggressive with the timing, but still on 11:1, just make sure you are tuned.</TD></TR></TABLE>
the SAFC is only for idle.
so how can i lower my CR since there is no aftermarket pistons for my engine.
Old Mar 15, 2005 | 02:33 PM
Dunc's Avatar
BCICAN
so how can i lower my CR since there is no aftermarket pistons for my engine.</TD></TR></TABLE>
wrong answer. Hondata deals with idle as well. If you have hondata, AEM, neptune, etc. there is no reason at all to have a AFC/SAFC....now I am not familiar with uberdata, but from what I hear, it is just like hondata and other software.
Old Mar 15, 2005 | 04:11 PM
WH0R3nEF9's Avatar
Im sure you can find pistons for that motor, but it'll take some dedicated digging. Some companies will make custom slugs. Ask around. For less work, you could try to find a thicker metal head gasket. That will lower the compression depending on how thick you get.
Jack_Havoc
Oct 14, 2008 07:50 AM
turbolsvtecalwaysbroken
Aug 12, 2006 07:29 AM
non-VTEC
Mar 20, 2006 05:41 PM
The DX Rex
Dec 28, 2004 07:25 PM
zip
Apr 22, 2003 09:07 AM
