clocking turbo
Old Mar 15, 2005 | 04:57 PM
AccidentproWn's Avatar
Default clocking turbo
Before anyone says search, i've already done that and yielded a few good suggestions.
Hey I'm trying to clock a turbo and i cant get the turbine side to budge at all... i've tried hiting it with a rubber mallet torching it, using WD-40, and using a breaker bar in the turbine inlet and compressor outlet and it wont budge, and of course combinations of both. Anyone have any advice? I really need to get this turbo clocked and it wont budge been at it for like 2 hours
Old Mar 15, 2005 | 05:20 PM
TunerToys's Avatar
Default Re: clocking turbo (AccidentproWn)
We normally break them loose using PB Blaster from Checker/Shucks/Kragen. Soak it daily for a few days, then it should tap loose. Major force should not be required, only patience...
Craig @ Tuner Toys
Old Mar 15, 2005 | 06:19 PM
Default Re: clocking turbo (TunerToys)
damn it i dont have a few days!
Old Mar 15, 2005 | 06:47 PM
nickromeo's Avatar
beat the **** out of it with a dead blow, if that doesnt work move onto a bigger hammer... thats what i did...
put a peice of wood ontop of trhe turbine housing and just beat the **** out of the inlet with a huge hammer through the peice of wood.
do it on a bench and be carefull you dont want your turbo to fly off your housing and damage the blades.
Old Mar 15, 2005 | 06:50 PM
dturbo's Avatar
Default Re: clocking turbo (nickromeo)
YES beat the **** out of the turbo. I had problems with clocking my turbo and I got sick of it and I smashed it real hard and it moved.
Old Mar 15, 2005 | 07:03 PM
Default Re: clocking turbo (flyazzcivic)
Geez this is really frustrating......this is like the 3rd going 4th hour on this. I can't go any further into installing anything else until i get the turbo on properly...bah !!!
Thank you for the suggestions though, please any more ideas are welcome.
Old Mar 15, 2005 | 08:32 PM
BluSiBoy's Avatar
Bump ! someone help this good guy out.... any other creative ideas out there ?
jv88_dc2
Jul 4, 2011 03:14 PM
CSRacing
Oct 19, 2005 05:27 AM
BlueShadow
Apr 28, 2005 08:22 PM
VtecAdil
Jan 13, 2005 11:24 AM
kell211
Mar 4, 2004 02:16 PM
