Dyno Preperation
Old Mar 12, 2005 | 05:23 PM
tony1's Avatar
Default Dyno Preperation
Ok, this has happened alot lately, to me and other tuners I talk to. It seems alot of people are neglecting the basics when it comes time to get their cars tuned. Please, for your own sake, make sure your car is ready for tuning. Dyno time is not cheap, and it's not the place to be doing general maintainance on your car. A few dollars spent in preperation will save you big money in the long run. You need to make sure your cap and rotor are in good condition, if not brand new. They're very cheap pieces compared to what your motor costs and what dyno time costs. Spark plugs, make sure they're new or that you have a new set with you. Spark plug wires, if they're not fairly new, replace them or at least have a new set with you in case you need them, you can always return them if you don't need them and are a real cheap ***. lol. DON'T run Ractive wires, they have too much RF noise and they **** up everything electrical within sight! Fuel filter, if there's more than 40k on it, replace it. Belts, make sure they're in good condition, if one breaks on the dyno, it's pain in the *** to change. For the most part, that's it. These little things will help you dyno session be short and sweet, saving you money in the long run. Nothing is better than a smooth problem free dyno session.
Old Mar 12, 2005 | 05:27 PM
HRTuning's Avatar
Default Re: Dyno Preperation (tony1)
Seriously... I hear the same things from everyone I talk to...Prepare your setup BEFORE you come in for *tuning*... Tuning does not mean maintenance...
Old Mar 12, 2005 | 05:34 PM
igo4bmx's Avatar
here is a good thread about being prepared for the tuning/dyno
http://www.evans-tuning.com/viewtopic.php?t=1635
Old Mar 12, 2005 | 05:44 PM
tony1's Avatar
Default Re: (igo4bmx)
Much better than mine! lol
Old Mar 12, 2005 | 06:30 PM
Squirtle's Avatar
Good write up!
Old Mar 12, 2005 | 06:59 PM
93turbo16's Avatar
I agree with that. When driving around on a basemap, the car tends to be rather rich, especially if running with out O2, for those to lazy to put one in. Plugs will need replaced, that is the biggest problem I run into.
Old Mar 12, 2005 | 07:53 PM
FastEK9's Avatar
Default Re: (93turbo16)
Amen....
Old Mar 12, 2005 | 08:11 PM
SOHC_MShue's Avatar
Good writeup. I was tuning a guy's car the other week and he had tons of problems! His tranny was making terrible sounds and felt like it was going to die, his car kept overheating, and when i went to check his plugs his cheap plug wires came apart while pulling them out and got stuck on top of the plug so i couldn't pull it out
Old Mar 12, 2005 | 08:20 PM
Danger's Avatar
Default Re: Dyno Preperation (SOHC_MShue)
you are one helpful guy
Old Mar 12, 2005 | 08:32 PM
Rod.'s Avatar
Default Re: (FastEK9)
Good info , I had so many problems when tony was tuning my car. This time I hope to have no problems and throw it right on the dyno
Old Mar 12, 2005 | 10:18 PM
Suprdave's Avatar
Default Re: (redturbocivic)
Here's one...If you have MSD Ignition, make sure the coil is BRAND NEW and is all properly wired up. Ask me why I suggest this...
Old Mar 12, 2005 | 10:22 PM
done's Avatar
and if your car ******* sucks, you should not dyno....
ive dynoed 3 fking times in the last 3 months.. all have been useless... ******* car!!!!!!!!!!!!!!!!!!!!!!!!111
Old Mar 12, 2005 | 10:27 PM
Adi Radoncic's Avatar
On Fire!
Default Re: (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">Here's one...If you have MSD Ignition, make sure the coil is BRAND NEW and is all properly wired up. Ask me why I suggest this...</TD></TR></TABLE>
Why do you suggest this?? LOL!!
Yeah he is right, I had all kinds of problems with my coil and dig6 and waisted 2 hours on the dyno not being able to rev past 5k.... Definitely something I should have taken care of before the car was dynoed but I was in a HUGE rush... Live and learn I guess!
Make sure your car is running properly before the dyno time, fix all your boost leaks, exhaust leaks exc.. $100 per hour to chase down little **** and do a maintenance tune up on your car isn't cheap in my book.
Old Mar 12, 2005 | 11:50 PM
SHystrdyGSRtdy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">.... Nothing is better than a smooth problem free dyno session. </TD></TR></TABLE>
your own personal dyno or free dyno time is
Old Mar 13, 2005 | 12:11 AM
HRTuning's Avatar
Default Re: Dyno Preperation (SHystrdyGSRtdy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">your own personal dyno or free dyno time is </TD></TR></TABLE>
A smooth problem free dyno session &gt; free dyno time...
Old Mar 13, 2005 | 02:05 AM
Ray-mond's Avatar
Old Mar 13, 2005 | 04:19 AM
FredoSP's Avatar
Default Re: Dyno Preperation (1Guamracer)
good info
Old Mar 13, 2005 | 09:07 AM
PrecisionH23a's Avatar
Does that mean I can't run my OBX chrome bling wires anymore?
Also make sure your spark plugs are already gapped. It's better to be on the smaller side then having to regap them when they are hot as hell.
Old Mar 13, 2005 | 09:38 AM
sharkcohen's Avatar
Default Re: Dyno Preperation (PrecisionH23a)
It may sound ultra simple, but make sure you have enough fuel. And if by the third pull things are not operating properly, get it off the dyno and go back another day. Troubleshooting for $100-$200 per hour is not something you want to pay.
Old Mar 13, 2005 | 09:40 AM
getnasty's Avatar
well wht do you guys suggest? im planning on haveing my car steet tuned by jason hunt (neptune) how can I check all of this before I trailer it? when I get my ecu done. does it come with a good base map? so I can check for these things? do I have to trailer it? will the base map be okay for 60 -70 miles of easy highway driving? the last thing I wanna do is **** of my tuner because I have leaks, and blowing plugs...
Old Mar 13, 2005 | 09:55 AM
SOHC_MShue's Avatar
Default Re: Dyno Preperation (bottle fed)
if they make you a proper basemap then i don't see any reason why you could cruise 60-70 miles over there. You may not want to get on it too hard, and your gas mileage might kinda suck, but it should be able to get you there just fine.
Old Mar 13, 2005 | 09:59 AM
getnasty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">if they make you a proper basemap then i don't see any reason why you could cruise 60-70 miles over there. You may not want to get on it too hard, and your gas mileage might kinda suck, but it should be able to get you there just fine. </TD></TR></TABLE>
no I wouldnt drive to hard. just get me there so I can play on the way back and I would be happy. its just such a pain getting my car on my trailer. and I wouldnt wanna risk blowing my car up..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Much better than mine! lol </TD></TR></TABLE>
hey tony you have a pm
Old Mar 13, 2005 | 10:52 AM
Sohc Driver's Avatar
Before my tuning session, I did a valve adjustment, replaced my distributor cap, rotor, spark plugs, plug wires, oil, oil filter, and underwear .
Khoi
Blaze45's Avatar
Brrraaaap!
TTT for a good thread!
Old Mar 13, 2005 | 01:31 PM
st00pid's Avatar
Default Re: Dyno Preperation (Blaze45)
AMEN!! thank you tony!! Motion to sticky.
