RC Injectors Question
Old Mar 14, 2005 | 10:47 AM
ldanphanl's Avatar
Default RC Injectors Question
i got me a set of 370 RC incjectorrs for my D16A6 SOHC non-vtec motor, its a OBD-0 , is there any re-wiring that i need to do, inorder to get them to run properly, because it feels like my car is about to stall off everytime i release the gas pedal, and every once in a while check engine comes on. i was thnking that it might be a wiring issue or something, i heard that those with OBD-1 ecus needs rewiring but do the OBD-0 needs too also?
thanks ahead for any imput
AyuDan
Old Mar 14, 2005 | 11:39 AM
Dunc's Avatar
BCICAN
Default Re: RC Injectors Question (ldanphanl)
well first off, what fuel management do you have that's allowing you to run the 370's?
Old Mar 14, 2005 | 11:43 AM
ldanphanl's Avatar
uh oh, by thaat question, it looks like somehtings wrong, im running the stock ecu pm6, i was bored and just installed.
Old Mar 14, 2005 | 12:39 PM
bbarbulo's Avatar
high or low impedence injectors??
Old Mar 14, 2005 | 12:54 PM
ldanphanl's Avatar
Default Re: (bbarbulo)
iono how can you tell? th RC on injector is red if that helps
Old Mar 14, 2005 | 12:57 PM
TunerToys's Avatar
To run any injector larger than stock, you'll need fuel management such as AFC, SMC, standalone, etc.
The factory ecu is not equipped to adjust for injectors that flow roughly 50% more than stock. It can handle adjusting a few percent here and there, but not 50% difference.
You need to be using management to compensate for the injector size. The SMC, AFC, etc, will do this correction for you. You can use the management to correct minus30% (example) across the RPM range, to bring your 390cc injectors back down to 230cc where they should be (assumption here is that your stock injectors are 230cc).
Then later, when you add your turbo, you can have your management allow those injectors to open up as needed depending on where your boost comes on at. You'll keep them corrected down to stock levels whe you are not boosting.
Hope that helps.
As for impedance, low = 2-4 ohms and high = 10-12 ohms. You can measure impedance with an Ohm meter. Check here for instructions on how to measure - http://stores.ebay.com/Tuner-T....html
Craig @ Tuner Toys
Modified by TunerToys at 10:08 PM 3/14/2005
Old Mar 14, 2005 | 08:11 PM
Dunc's Avatar
BCICAN
Default Re: RC Injectors Question (TunerToys)
well said TunerToys....agreed, you need some kind of fuel management.
Old Mar 15, 2005 | 03:34 PM
del_orson's Avatar
Default Re: RC Injectors Question (Dunc)
down load Crome. Use base maps and scale your injectors. You will need your ECU modified.
Old Mar 15, 2005 | 03:35 PM
dustin's Avatar
Yeah you can't just run larger injectors without fuel management.
Old Mar 15, 2005 | 04:06 PM
splitime's Avatar
Default Re: RC Injectors Question (del_orson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_orson &raquo;</TD></TR><TR><TD CLASS="quote">down load Crome. Use base maps and scale your injectors. You will need your ECU modified.</TD></TR></TABLE>
Ignore this. Crome is for obd1 cars... not obd0.
If you pm6 is chippable... 90-91. YOu can chip it and run TurboEdit.
Goto http://www.pgmfi.org and start reading
As it stands... you can't run those injectors on your car without management... period.... it'll just run like crap... if at all.
DIRTYsouthBB6
Nov 8, 2007 08:23 PM
channy
Jul 24, 2005 08:09 PM
ldanphanl
Mar 14, 2005 12:24 PM
UncleBen'sRacing
May 20, 2003 03:17 AM
whagkangmakulet
Dec 24, 2002 07:21 AM
