spark plug pic, this mean's lean right?
Old Mar 11, 2005 | 12:09 PM
c61lude's Avatar
Default spark plug pic, this mean's lean right?
well I comp tested my car for anyone that remembers me and it was 190 accross the board on a cold motor. One thing that was alarming to me though was the color of my spark plugs, I'm under the impression this means lean but why does my wideband say I'm running 11.5-12. when I'm wot yet my plugs say lean ?? Here's some pics
Old Mar 11, 2005 | 12:10 PM
SL0WEGG's Avatar
Default Re: spark plug pic, this mean's lean right? (c61lude)
black means rich. i think white means lean
Old Mar 11, 2005 | 12:12 PM
J337_UNIT's Avatar
those plugs look ok to me... not the typical brown color your looking for but i dont see and signs of detonation on there
s2kdre's Avatar
Default Re: spark plug pic, this mean's lean right? (boostedej1)
they look good to me. my air fuel is 11.2 and those plugs look like mine.
Old Mar 11, 2005 | 12:13 PM
h22 civic's Avatar
Default Re: spark plug pic, this mean's lean right? (jdmhonda)
actually need a better close up pic
Old Mar 11, 2005 | 12:19 PM
Hyaboosta's Avatar
Default Re: spark plug pic, this mean's lean right? (h22 civic)
if they were white and looked like powdery then that would be lean. they look barley rich but thats not a bad thing on boost. i'de rather be on the rich side.
Old Mar 11, 2005 | 12:21 PM
b18bturbo's Avatar
Default Re: spark plug pic, this mean's lean right? (Hyaboosta)
you have to be careful reading plugs running any thing but std fuel the additives within the gasonline tend to give it white coating. Its the additives in race gas and other gases that cause the white but it also could be lean. You need to inspect more or less fo signs of detonation
Old Mar 11, 2005 | 12:27 PM
wHOAlly's Avatar
Default Re: spark plug pic, this mean's lean right? (b18bturbo)
those pics suck, but from what i can tell, looks perfect
Old Mar 11, 2005 | 12:48 PM
99lspwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c61lude &raquo;</TD></TR><TR><TD CLASS="quote">well I comp tested my car for anyone that remembers me and it was 190 accross the board on a cold motor. One thing that was alarming to me though was the color of my spark plugs, I'm under the impression this means lean but why does my wideband say I'm running 11.5-12. when I'm wot yet my plugs say lean ?? Here's some pics
First off you are supposed to do a compression test on a motor thats been fully warmed up, and also those plugs look way to new to really tell anything...Get some miles on them and take some more pics....Obviously you know your a/f looks good, so as long as your timing maps are ok you should be fine,..
Old Mar 11, 2005 | 12:51 PM
HitEm'Up's Avatar
Its hard to see it does look alittle white on the tips--could be alittle lean
Old Mar 11, 2005 | 12:54 PM
VTC_CiViC's Avatar
Did you pull those plugs after the car idled or did you turn the key off in the middle of a WOT run?
Old Mar 11, 2005 | 12:55 PM
Paul_VR6's Avatar
Default Re: spark plug pic, this mean's lean right? (VTC_ohgodnotagain_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_ohgodnotagain_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Did you pull those plugs after the car idled or did you turn the key off in the middle of a WOT run?</TD></TR></TABLE>
Yep, you have to shut down in the middle of a pull to really read em on an EFI car.
Old Mar 11, 2005 | 12:57 PM
c61lude's Avatar
Default Re: spark plug pic, this mean's lean right? (Sp00n'd Supra)
alright here's a good pic of all 4 plugs
Old Mar 11, 2005 | 01:02 PM
Mase's Avatar
its rich. (doesnt always mean rich in boost) but somewhere on the load range its runnin rich
Old Mar 11, 2005 | 01:05 PM
c61lude's Avatar
Default Re: spark plug pic, this mean's lean right? (99lspwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr &raquo;</TD></TR><TR><TD CLASS="quote">
First off you are supposed to do a compression test on a motor thats been fully warmed up</TD></TR></TABLE>
I cannot warm the motor up I blew the crank seal out of it and I wanted to decide weather or not it was worth investing more money into it. "crank seal, bottom end gasket's, manual tensioner swap, timing belt". So compression only gets better as you warm the car up correct? because pistons and rings expand more than the piston wall/sleeve.
Old Mar 11, 2005 | 01:15 PM
Rtype16's Avatar
The guy who says you need to drive the car around to get a good reading doesn't know what he is talking about. You can do one run on the plugs shut thecar off and I could read them.
From what i can tell about your plugs is you are running fine. The green/white color on the tops of the plug are from the additives in the gas. Not a problem there. The black around the outside of the plugs and deep in the porcelin means you are running rich right at startup and warmup. Other than that plugs look great. No signs of detonation.
Old Mar 11, 2005 | 01:39 PM
Blaze45's Avatar
Brrraaaap!
Default Re: spark plug pic, this mean's lean right? (Rtype16)
If you want to know what your WOT plug looks like, you gotta do a pull and shut down at the top of the run to see if there is any signs of pre ig. or deatonation to get the best idea of whats going on under boost or WOT.
Good Luck, safe boosting
Blaze
Old Mar 11, 2005 | 01:46 PM
h22 civic's Avatar
Default Re: spark plug pic, this mean's lean right? (Blaze45)
the good way to do a test is take a full blown 1/4 mile pass and shut the car down at the end roll to a stop and check your plugs ,do not give the car gas once you let go of the throtlle that will defeate the whole purpose
Old Mar 11, 2005 | 03:58 PM
oxSLEEPERxo's Avatar
http://www.dansmc.com/Spark_Pl....html
Old Mar 11, 2005 | 05:40 PM
Sage972's Avatar
Default Re: spark plug pic, this mean's lean right? (oxSLEEPERxo)
those plugs just have some carbon build up it is not a lot but if you would like to clean them get a small parts sand blaster that is what i use all the time cleans them up good as new
Old Mar 11, 2005 | 06:01 PM
alpha's Avatar
Default Re: spark plug pic, this mean's lean right? (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">its rich. (doesnt always mean rich in boost) but somewhere on the load range its runnin rich</TD></TR></TABLE>
+1
Do a pull, turn off the motor (at peak torque or at the top of your powerband) and post pictures.
Old Mar 11, 2005 | 10:03 PM
c61lude's Avatar
Default Re: spark plug pic, this mean's lean right? (0x64)
will do. Thanks hommies
central_driver
Sep 1, 2010 03:52 AM
J.nguyen
Sep 23, 2006 01:07 PM
91 lude si
Sep 6, 2004 04:29 PM
TORQUE MONSTER
May 22, 2003 12:00 PM
Duck Sauce
Dec 6, 2001 04:23 PM
