ground wire for oil pressure gauge....
New User
the instruction says to mount the ground wire in the engine bay near the oil sender. i hooked it up inside the car under the dash. will i be ok? or should i just move it to be safe? i don't see what the difference would be.
BTW, the ground is for the oil pressure GAUGE.
Modified by Unjockable at 8:37 PM 3/14/2005
Re: ground wire for oil pressure gauge.... (Unjockable)
A ground is a ground. . Just re-ground your engine with better wire to make sure it's getting a good signal (If you haven't already)
Re: ground wire for oil pressure gauge.... (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">A ground is a ground</TD></TR></TABLE>
I would have to dissagree there. There is a such a thing as ground resistance... Not usually a problem in a car, but this is a very voltage-sensitive device. Do what the instructions say, to at least be sure you are as accurate as possible.
