flat top pistons?
Old Mar 11, 2005 | 06:14 PM
ochsy03's Avatar
Default flat top pistons?
what r flat top pistons? i searched like crazy
r they for turbo cars?
Old Mar 11, 2005 | 08:56 PM
earl's Avatar
Default Re: flat top pistons? (ochsy03)
Flat top means that they don't have a domed top for all motor high compression or a dished top for lower compression turbo. The top is flat except for the valve reliefs cut into it.
Old Mar 11, 2005 | 10:42 PM
ochsy03's Avatar
Default Re: flat top pistons? (earl)
are flat top good for turbo?
Old Mar 11, 2005 | 11:25 PM
earl's Avatar
they will give you 9.7 -10.0-1 compression ratio. A little high for street tuning and octane.
Old Mar 12, 2005 | 12:09 AM
Tad's Avatar
Tad
well...
depends on the height of the piston too,
could be some wierd low *** piston with a flat top and wont make much compression..
Old Mar 12, 2005 | 09:48 AM
ochsy03's Avatar
Default Re: flat top pistons? (Tad)
heres the pistons: Arias CUSTOM 9.5 flat top pistons
Old Mar 12, 2005 | 10:40 AM
turboEGhatch's Avatar
All that means is instead of having a dish in them, they are a flat top.
http://www.ariaspistons.com/pr...s.pdf
Open that up, look at the pistons on page 1. The top piston is a dished piston, second piston is a flat top.
Old Mar 12, 2005 | 07:10 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ochsy03 &raquo;</TD></TR><TR><TD CLASS="quote">heres the pistons: Arias CUSTOM 9.5 flat top pistons</TD></TR></TABLE>
well there ya go,
they're just called flattop cuz they happen to have no dish or dome, just completely flat!
But the CR is what they do, and it is 9.5 aparently.
so you could use them for a turbo application if you wanted,
would be nice and fairly responsive, but still not too hard to tune,
just kinda mid range as far as compression goes...
would be sorta low for an allmotor application though..
for refrence, most dseries engines are around 9.2, b16's are.. what.. 10.3 ?
Old Mar 12, 2005 | 08:33 PM
SOHC_MShue's Avatar
even the d16y8 has a stock compression of 9.6:1. I think those pistons will be fine for boost.
dc2_916
Sep 14, 2008 10:23 AM
CXtypeR
Jan 4, 2007 07:11 PM
Bspec18
Oct 4, 2005 03:11 PM
legoman
Jan 25, 2005 01:49 PM
Teal95Coupe
Aug 17, 2003 05:12 PM
