T3 3-Bolt Discharge Flange (Internal Gate)
This should be here instead of the classifieds hopefully.......
I am looking for a Steel T3 3-Bolt Discharge Flange for an Internal Wastegate setup. I can't seem to find the right flange for my turbo. I just purchased a flange and a gasket from ATPturbo.com and it was too small. The measurement from the center of each mounting hole to the next on the "small" flange and gasket is approx. 2.86". The diameter of the hole is approx .38". I need a flange that has the measurement of 3.37" from the center of each mounting hole and with the same diameter of .38" for each actual mounting hole. The outlet of the flange has to be 2.5". Does anyone know where I can get the flange that I described above. I have already emailed WeirRacing and BMCRace, but I just wanted to see if anyone knew if a vendor sells it so I don't have to wait to get the flange made, etc.
Also if this helps or not, I have the swingvalve housing ID numbers. Garrett M-3; PT-8.
Any help IS greatly appreciated. Thanks.
1.8T_EG
05-15-2003 09:37 PM
