i did a compression check...
Old Mar 15, 2005 | 07:40 PM
tony n.'s Avatar
Default i did a compression check...
i got 120 on all 4 cyclinders.....is that good for turbo???
Old Mar 15, 2005 | 07:44 PM
s2kdre's Avatar
Default Re: i did a compression check... (boosted2cam)
what motor is it? my ls is 9:5 and i had 185 across the board.
Old Mar 15, 2005 | 07:46 PM
tony n.'s Avatar
Default Re: i did a compression check... (jdmhonda)
b16a
Old Mar 15, 2005 | 07:49 PM
s2kdre's Avatar
that motor should have at least 200 across the board. its 10:1 comression. Damn thats kind of low numbers, but as long as they are equal numbers boost the hell out of it and have fun.
Old Mar 15, 2005 | 07:51 PM
FredoSP's Avatar
please explain how you did the test.. did you do it WOT and was the engine hot or cold.
120psi sucks, id bet you did it on cold engine and NOT WOT.
Old Mar 15, 2005 | 08:01 PM
Civicman86's Avatar
Default Re: i did a compression check... (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">
120psi sucks, id bet you did it on cold engine and NOT WOT.</TD></TR></TABLE>
IM guessing the same. i have accidentaly done it without WOT and it makes a huge difference.
Old Mar 15, 2005 | 08:15 PM
f22b2tdave's Avatar
Default Re: i did a compression check... (Civicman86)
ooor maybe he did the test right and he just has 120....do a leakdown, altough if all 4 are about the same...maybe it was just a testing error, but as long as they are consistent i say go for it.
Old Mar 15, 2005 | 08:18 PM
dustin's Avatar
Default Re: i did a compression check... (f22b2tdave)
Or maybe his compression tester is junk since the numbers are consistent across the board.
skaternak
10
Aug 9, 2009 05:48 PM
sohctodohc
13
Mar 7, 2007 05:53 PM
-Darren-
May 23, 2006 02:29 PM
dohcter g
17
Mar 23, 2005 07:47 PM
92TypeR
Aug 21, 2003 01:51 PM
