GT28RS Housing Nipple?
Does anyone know if the GT28RS compressor housing has a 1/8" NPT hole tapped into the outlet already? Need to know cause I'm abotu to order my turbo off ATP and not sure if I should order their quicktap or not.
Re: GT28RS Housing Nipple? (boosted hybrid)
why do you want to get a boost signal from the compressor cover? it's not the same boost your engine sees after the losses from the IC and piping.
from tests on my setup. I see less then .2 PSI differnece from turbo outlet vs IM at 10.5PSI so I jsut tune according to that correction in mind. Plus the vacuum line is nice and short.
And thanks Jeff
And thanks Jeff
