"closed,open" deck block?
Old Mar 13, 2005 | 10:15 AM
one4darkstar's Avatar
Default closed or open deck block?
I am planning on either putting an h22 in my accord then when i have more money getting it built and putting on a turbo kit.OR-building up the f23 to handle some boost(up to 15psi)and then putting on a turbo kit. My question is about closed deck blocks-what exactly does this mean? I am guessing that "closed deck" is referring to the coolant passages around the cylinders on some honda blocks. I heard the h22 is more prone to problems if the boost is turned up high. Is the h22 closed or open deck? Is the f23 closed or open? Which is more prone to failing under high boost pressures? Thanks for the help
Modified by one4darkstar at 11:49 AM 3/13/2005
Old Mar 13, 2005 | 10:42 AM
h22 civic's Avatar
Default Re: "closed,open" deck block? (one4darkstar)
what year block?
Old Mar 13, 2005 | 10:54 AM
Default Re: "closed,open" deck block? (h22 civic)
Thanx for your help but what does a header shop website a transmission website and a efi site have to do with a question about closed deck blox?
Modified by one4darkstar at 12:18 PM 3/13/2005
Old Mar 13, 2005 | 10:56 AM
RudeLude's Avatar
92-96 are closed (4gen h22a), 97+ are open
Old Mar 13, 2005 | 11:05 AM
h22 civic's Avatar
Default Re: closed or open deck block? (one4darkstar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one4darkstar &raquo;</TD></TR><TR><TD CLASS="quote"> Is the h22 closed or open deck? Is the f23 closed or open? Which is more prone to failing under high boost pressures? Thanks for the help
Modified by one4darkstar at 11:49 AM 3/13/2005</TD></TR></TABLE>
like i said what year is the block
Old Mar 13, 2005 | 11:22 AM
Thank you for your help on the h22 block. Now does anyone know about the f23 block(closed or open?).-And which is best for boost closed deck or open?
Old Mar 13, 2005 | 11:25 AM
Sorry h22 civic I missed part of your post
accord387's Avatar
f23 is open deck
Old Mar 13, 2005 | 12:23 PM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one4darkstar &raquo;</TD></TR><TR><TD CLASS="quote">Thanx for your help but what does a header shop website a transmission website and a efi site have to do with a question about closed deck blox?[/i]</TD></TR></TABLE>
ROFL, that's his sig.
Old Mar 13, 2005 | 12:25 PM
sharkcohen's Avatar
The H22A is closed deck, the H22A1 is closed deck, and the H22A4 is open deck. Not sure about the Euro block, but they are less common anyway. If you are getting it sleeved, it doesn't really matter whether the block is open or closed deck.
Old Mar 14, 2005 | 07:23 PM
Default Re: closed or open deck block? (sharkcohen)
My question is about closed deck blocks-what exactly does this mean? I am guessing that "closed deck" is refering to the coolant passages around the cylinders on some honda blocks? Is this correct? SO
Closed deck=no coolant passages and Open deck=coolant passages
Old Mar 14, 2005 | 07:42 PM
gitwidit's Avatar
closed deck
open deck
Old Mar 14, 2005 | 07:49 PM
Beau Gotti's Avatar
so the h22 in my 1997 prelude is a open deck...i
Old Mar 14, 2005 | 10:03 PM
PrettyLude's Avatar
Default Re: (beaussol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaussol &raquo;</TD></TR><TR><TD CLASS="quote">so the h22 in my 1997 prelude is a open deck...i</TD></TR></TABLE>
yes
Old Mar 15, 2005 | 09:47 AM
Pikachu's Avatar
Supposedly I heard open decks were better for boost due to the fact that there are more coolant passages. Don't know if it holds any validity.
Old Mar 15, 2005 | 09:54 AM
sporkcrx's Avatar
Default Re: (Pikachu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikachu &raquo;</TD></TR><TR><TD CLASS="quote">Supposedly I heard open decks were better for boost due to the fact that there are more coolant passages. Don't know if it holds any validity.</TD></TR></TABLE>
I don't know about that. Most factory turbo engines are closed deck that I can think of.
Old Mar 15, 2005 | 10:02 AM
Pikachu's Avatar
Ahh a turboedit user. Xenocron is a close friend of mine. Is there any validity to my open deck coolant question?
Old Mar 15, 2005 | 10:04 AM
PrettyLude's Avatar
Default Re: (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">I don't know about that. Most factory turbo engines are closed deck that I can think of.</TD></TR></TABLE>
correct
Old Mar 15, 2005 | 10:13 AM
Blackack26's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">
correct</TD></TR></TABLE>
Most, but not all
Here's a pic of my brothers volvo S70 block, open deck...
Old Mar 17, 2005 | 10:53 AM
h22 civic's Avatar
Default Re: closed or open deck block? (GITWIDIT)
here is a closed decked block with open decked sleeves it was custom made but it can be done
bomb proof
Modified by h22 civic at 10:05 PM 3/17/2005
Old Mar 17, 2005 | 10:58 AM
Rory Breaker's Avatar
So are there any more positives/negatives to open/closed decks?
Is the lack of coolant passages a real negative, or is there still sufficient cooling, it just doesnt look so obvious due to the closed deck?
sti runnen it
Oct 25, 2007 10:17 AM
igs22
Nov 29, 2006 12:17 PM
Charliegrs
Oct 25, 2006 03:27 PM
rollercosta123
Aug 30, 2006 07:28 PM
dipset18
Jan 13, 2005 12:35 AM
