After turbo install, getting check engine light.
Old Mar 13, 2005 | 08:30 AM
meltman1234's Avatar
Default After turbo install, getting check engine light.
OK I'm throwing code P1491 Auxilary Emissions Controls. I don't know what to do to fix it. I have a 98 Prelude and if you need any further information just post and I'll provide it. Thanks
Old Mar 13, 2005 | 08:46 AM
iconz116's Avatar
Default Re: After turbo install, getting check engine light. (meltman1234)
What type of engine management are you running? What is your setup?
Old Mar 13, 2005 | 09:11 AM
andysila's Avatar
P1491: Exhaust Gas Recirculation (EGR) Valve Insufficient Lift
http://www.ttzd.com/tech/egrtech.html
http://www.fordscorpio.co.uk/egr.htm
Old Mar 13, 2005 | 09:30 AM
sharkcohen's Avatar
Default Re: (andysila)
Did you remove or block your EGR?
Old Mar 13, 2005 | 12:01 PM
Default Re: After turbo install, getting check engine light. (iconz116)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iconz116 &raquo;</TD></TR><TR><TD CLASS="quote">What type of engine management are you running? What is your setup?</TD></TR></TABLE>
Right now all I have is a VAFC. I'm planning on getting emanage (because tuner here uses it a lot) soon. But I don't have the money.(But I"m not really driving the car so I don't have to worry about much now.)
Setup is....
t3/t4 turbo
custom manifold
custom downpipe 2.5 inch
wastegate with 8 1/2 pound spring
stock internals
450 cc injectors
255lph fuel pump
I think that's it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">Did you remove or block your EGR?</TD></TR></TABLE>
I don't know. I didn't install it myself. How can I check?
Thanks for the help.
Old Mar 13, 2005 | 05:35 PM
PrettyLude's Avatar
look by ur throttle body and see if your egr is still there.
it might be dirty, if its dirty take off the egr and clean it real good
Old Mar 13, 2005 | 07:11 PM
NVturbo's Avatar
O.G. triple O.G.
Do you even have a "missing link" since you don't have an engine management system?
Old Mar 13, 2005 | 07:18 PM
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">look by ur throttle body and see if your egr is still there.
it might be dirty, if its dirty take off the egr and clean it real good</TD></TR></TABLE>
Ok. I'll do that today and come back with results.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote">Do you even have a "missing link" since you don't have an engine management system?</TD></TR></TABLE>
I have a VAFC with the VAFC hack.
Modified by meltman1234 at 8:00 AM 3/14/2005
taylorbishops2k
Dec 24, 2012 03:48 PM
CNSK
Feb 2, 2007 03:06 PM
meltman1234
Mar 13, 2005 06:31 PM
flood
Jan 20, 2005 09:57 AM
1boostedgsr
Jul 18, 2004 07:50 PM
