Peak Boosted SI Dyno
Old Mar 14, 2005 | 02:13 PM
TheYellowDart's Avatar
Default Peak Boosted SI Dyno
lil vid towards bottom of page
Well first off i would like to thank Curt and the crew over at Dyno Tuned in Madison, WI for the tune.
Low boost was at 12 lbs
Hight boost was at 18 lbs
We would have made more power but my clutch was slipping way bad at top end.
Setup is peak boost kit
83mm b16 9:1
JG pro series head
Thermal 3"
Modified by TheYellowDart at 6:12 PM 3/14/2005
Modified by TheYellowDart at 1:44 AM 3/15/2005
Old Mar 14, 2005 | 02:18 PM
turboEGhatch's Avatar
Default Re: Peak Boosted SI Dyno (TheYellowDart)
Were you getting some boost creep on the low power pull? Torque never seems to peak, it just keeps sliding up. Nice numbers though, is this with a 57 trim?
elscotto80's Avatar
Nice numbers. Pictures?
Old Mar 14, 2005 | 02:25 PM
tthame1's Avatar
Default Re: Peak Boosted SI Dyno (elscotto80)
Nice numbers what turbo was this with and why didnt you rev higher?
Old Mar 14, 2005 | 02:26 PM
i will get some pics and maybe a video up later.
Old Mar 14, 2005 | 02:30 PM
Default Re: Peak Boosted SI Dyno (tthame1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthame1 &raquo;</TD></TR><TR><TD CLASS="quote">Nice numbers what turbo was this with and why didnt you rev higher?</TD></TR></TABLE>
did not rev higher because turbo was loosing efficiency(sp?) t67 is next. now its a 60 trim
Old Mar 14, 2005 | 02:41 PM
tthame1's Avatar
Im doing an 81.5 mm b16 right now with 9.2:1 cr, shooting for 400whp at 15psi with an sc61 That 67 should treat you real good.
Old Mar 14, 2005 | 03:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheYellowDart &raquo;</TD></TR><TR><TD CLASS="quote">
did not rev higher because turbo was loosing efficiency(sp?) t67 is next. now its a 60 trim</TD></TR></TABLE>
Considering you're still making within 13 ft-lbs of your peak torque when you let off, i'd say the turbo is fine. A 60 trim will make power to atleast 9K on a B16.
Old Mar 14, 2005 | 03:08 PM
shermanyang's Avatar
Default Re: Peak Boosted SI Dyno (turboEGhatch)
nice power. looks similar to my ls dyno...60 trim as well.
Old Mar 14, 2005 | 03:11 PM
D-tuned's Avatar
Default Re: Peak Boosted SI Dyno (shermanyang)
nice numbers. you need to rev it out some more.
Modified by 2000civicsi at 8:58 PM 3/14/2005
Old Mar 14, 2005 | 06:51 PM
11SEC CIV's Avatar
good job/ nice #'s--what injectors?/management are u running?
Old Mar 14, 2005 | 07:06 PM
Default Re: Peak Boosted SI Dyno (12SEC CIV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12SEC CIV &raquo;</TD></TR><TR><TD CLASS="quote">good job/ nice #'s--what injectors?/management are u running?</TD></TR></TABLE>
i used seimen deka injectors and hondata s200b.
Old Mar 14, 2005 | 09:38 PM
i got a little vid ready. how should i host it
Old Mar 14, 2005 | 10:24 PM
link did not work
Old Mar 14, 2005 | 10:27 PM
ahha when it opens in windows media it asks if it is a trust worthy source say yea and it works
http://www.we-todd-did-racing....DE%3D
Old Mar 15, 2005 | 12:56 AM
H.A.R.T B18C1EG6's Avatar
Si is niiice good video too
Old Mar 15, 2005 | 03:48 AM
BoostedsiR's Avatar
Default Re: Peak Boosted SI Dyno (F.A.S.H B18C1EG6)
that should be a nice powerband to match with thoose short gears.
Old Mar 15, 2005 | 07:08 AM
Carlito Brigante's Avatar
Default Re: Peak Boosted SI Dyno (BoostedsiR)
That #'s look great.
Ricky
Old Mar 15, 2005 | 09:51 AM
Default Re: Peak Boosted SI Dyno (WIRED RICKY)
ls tranny
Old Mar 15, 2005 | 10:28 AM
turbo*s2k's Avatar
looks good congrats!
Old Mar 15, 2005 | 12:05 PM
11psiTurboSI's Avatar
Default Re: Peak Boosted SI Dyno (TurboChrgd_Civic)
Nice #'s
Old Mar 15, 2005 | 01:12 PM
SHystrdyGSRtdy's Avatar
Default Re: Peak Boosted SI Dyno (11psiTurboSI)
that vid with no traction put a smile on my face
Old Mar 15, 2005 | 01:26 PM
HitEm'Up's Avatar
Nice numbers
Old Mar 15, 2005 | 04:05 PM
PeakBoost's Avatar
B*A*N*N*E*D
very nice!
shes got more in her, just need to hold the power
keep us updated and tell kurt that ken says whats up!
peak
Old Mar 15, 2005 | 04:55 PM
itslogics's Avatar
Default Re: Peak Boosted SI Dyno (PhoenixTurbo.com)
I see that your in Swansea? Isn't that close to Saint Louis? Well anyways if it is, then what shop do you goto? and who tuned it? Awesome numbers by the way
