310cc injectors
Old Mar 13, 2005 | 07:30 PM
CRAZYHONDA's Avatar
Default 310cc injectors
will 310cc be enough for 8psi with uberdata. dont want to cut any factory wire for 450cc or should i just get the 450
Old Mar 13, 2005 | 07:33 PM
adseguy's Avatar
Default Re: 310cc injectors (CRAZYHONDA)
only 4.2 PSI
seriosuly though it's horsepower that matters not PSI. 450's are good to about 280-320 HP....rough estimate and depends on the tuner. Get the 450's so you have room to play with.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRAZYHONDA &raquo;</TD></TR><TR><TD CLASS="quote">dont want to cut any factory wire for 450cc </TD></TR></TABLE>
your putting a turbo on your car and worried about cutting a few stock wires? . All you need is a resitor box...no cutting
Old Mar 13, 2005 | 07:40 PM
CRAZYHONDA's Avatar
Default Re: 310cc injectors (adseguy)
can you use inlines resitor.i heard you need dsm injector clips to. i'm putting it on a 97 y7
Old Mar 13, 2005 | 07:42 PM
wantboost's Avatar
Who is Mr Robot?
the inline resistors will work, but it doesnt look as clean as a resisitor box IMO.
yes, you need obd-1 injector clips
Old Mar 13, 2005 | 07:44 PM
TunerToys's Avatar
Somewhere I saw something about a company that sells 450s that are direct drop-in's for the oem injectors. No goofing with the seals, and they plug right in on OBD1 and OBD0 Hondas. OBD2 Owners get free injector clips. No need to add a resistor box, as high and low impedance styles are available.
"Tuner...." something. Man it's right on the tip of my tongue. Something "...Toys". Just can't remember. Dang. Sorrry.
Old Mar 13, 2005 | 07:51 PM
CRAZYHONDA's Avatar
Default Re: 310cc injectors (wantboost)
why cant i use my stock injector clip. weren't obd1 and obd2 injectror clip the same
Old Mar 13, 2005 | 08:00 PM
TunerToys's Avatar
Nope, Here is the breakdown for Honda...
OBD0 - 1988 to 1991
OBD1 - 1992 to 1995
OBD2 - 1996 - 2000
The 1996 - 2000 cars use a different injector clip. The OBD0 and OBD1 cars use the same clip.
Old Mar 13, 2005 | 08:05 PM
CRAZYHONDA's Avatar
Default Re: 310cc injectors (TunerToys)
so if i buy 450cc i will have to cut my injectors clip and find dsm clip or obd1 clip for it to work. is there any way i can use my stock clips
Old Mar 13, 2005 | 08:07 PM
wantboost's Avatar
Who is Mr Robot?
no, obd2 clips wont work at all. a fact of life is that you are going to have to cut wires
Old Mar 13, 2005 | 08:11 PM
CRAZYHONDA's Avatar
if i use obd1 clip y do a need a resisitor box. a clip a clip WTF is there magic in obd1 clip it look the same.
Old Mar 13, 2005 | 08:19 PM
wantboost's Avatar
Who is Mr Robot?
because the 450's are peak and hold, which are high impedance, the stock saturated injectors are low impedance. the injectors drivers in the ecu cant handle that big of a load with out failing, so you need the resistor box to fool teh ecu into thinking that its still driving the low impedance injectors
also, the clips look same externally, but its the pin configuration and the inner desgin of the clip that matters
Old Mar 13, 2005 | 08:23 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">because the 450's are peak and hold, which are high impedance, the stock saturated injectors are low impedance. the injectors drivers in the ecu cant handle that big of a load with out failing, so you need the resistor box to fool teh ecu into thinking that its still driving the low impedance injectors
also, the clips look same externally, but its the pin configuration and the inner desgin of the clip that matters</TD></TR></TABLE>
backwards, but on the right track..
Our injectors are high impedance, that is why you need the resistor box with low impedance injectors, to bump up the resistance.
Since resistance is a factoer between voltage and current, V=IR if you have more reistance, and the same voltage, you need lower current.. the high current of the low impedance injectors is what cooks the injector drivers in the ecu.
Old Mar 13, 2005 | 08:26 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: 310cc injectors (93turbo16)
im sick, so im allowed to make a few mistakes
Old Mar 13, 2005 | 08:28 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">*** .
im sick, so im allowed to make a few mistakes</TD></TR></TABLE>
I will let it slide this time. Hope I am right though.. haha
Old Mar 13, 2005 | 08:46 PM
CRAZYHONDA's Avatar
ok,96+ prelude injector 390cc or 345 will it be plug and play. will it enough for 8psi
Old Mar 13, 2005 | 08:48 PM
93turbo16's Avatar
yea, they would be enough for 8psi. But will be very very close to maxing the 345s.
mortificationrock
May 3, 2007 09:33 PM
Black R
Nov 17, 2004 03:00 PM
huntarrr
Nov 7, 2004 06:12 PM
Built B16A
Jul 4, 2004 06:05 PM
1strdko
Aug 17, 2003 08:56 AM
