b20vtec project
Old Mar 12, 2005 | 04:23 PM
b20vtechatch
Guest
Posts: n/a
Default b20vtec project
b20 84mm honed and hot oil tanked, b20 crank polished, eagle h-beams, ross pistons 8.5:1, ross rings, arp main bolts, aftermarket block girdle, type-r oil pump, type-r water pump, gs-r pick up, moroso oil pan, block gaurd, Eagle vtec conversion kit, everything was done perfect. i have a b16 head. My question is what stage cams do i get for b20vtec turbo? And also what port and polish and angle valve job do i need? last question how do i post pics up? id like to show you my progress thanks!!
Old Mar 12, 2005 | 05:36 PM
b20vtechatch
Guest
Posts: n/a
Default Re: b20vtec project (b20vtechatch)
any recomendations
Old Mar 12, 2005 | 06:04 PM
B20TDC2's Avatar
cams depend on what power your looking for & is the head built (ie springs retainers ) skunk2 has turbo cams you might just want to get some type r cams . for pics you can open an we todd account or pay for iserve account
Old Mar 13, 2005 | 09:12 AM
b20vtechatch
Guest
Posts: n/a
Default Re: b20vtec project (B20TDC2)
i wanted a least 300 horse i want titainium retainers, dual stage valve springs, if i get stage 2 cams jun, toda or skunk2, what valves do i get. what do i have to do to have at least stage 2. i dont want stage 1. can i obtain 300+ with stage one?
Old Mar 13, 2005 | 10:08 AM
B20TDC2's Avatar
hell you can get 300 with stock cams imo you should invest the money your planning on spending on cams and get an lsd. 300+ is easily obtainable with stock cams. look at my sig thats on stock cams
EduardoDC5
Aug 21, 2010 10:23 AM
Don E
Feb 28, 2010 09:21 PM
one slow coupe
19
Feb 9, 2006 03:45 PM
HARI.
Sep 19, 2004 09:49 PM
chinners10
Apr 24, 2003 08:38 PM
