emission problem on stock b16a2
Old Mar 12, 2005 | 08:44 AM
dnbruut's Avatar
Default emission problem on stock b16a2
heres the story: stock b16a2, still unboosted, cai and open mufler.
vafc completely set to zero.
idle: co is ok (0.01) lambda is 1.18 (lean)
3000rpm co is 8.2 lambda is ok (1.00)
can annybody see the logic in this? annybody ever had this problem?
only a few days untill the next emission test.
thanks!!!!!!!!!!!!!!!
Old Mar 12, 2005 | 09:19 AM
dnbruut's Avatar
Default Re: emission problem on stock b16a2 (dnbruut)
annybody?
Old Mar 12, 2005 | 10:16 AM
dnbruut's Avatar
annybody got more brains than the average????
Old Mar 13, 2005 | 08:22 PM
Rusty B16AT's Avatar
Buy an Air/Fuel ratio gague. You will need one when you go boost anyways. Than you can adjust your VAFC perfectly. Or Go eManage and buy the support tool and hook it up to a lap top. ALL you need to do is Stay 14.7:1 to stay stoiciometric.
Old Mar 14, 2005 | 07:16 AM
tgreaves's Avatar
Default Re: emission problem on stock b16a2 (Rusty B16AT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rusty B16AT &raquo;</TD></TR><TR><TD CLASS="quote">Buy an Air/Fuel ratio gague. You will need one when you go boost anyways. Than you can adjust your VAFC perfectly. Or Go eManage and buy the support tool and hook it up to a lap top. ALL you need to do is Stay 14.7:1 to stay stoiciometric.</TD></TR></TABLE>
An air/fuel gauge isnt going to show you anything good.. If you want to get your 14.7 air/fuel then get a wideband and tune with that, or go to a dyno..
Are you running some kind of afc hack or anything? Where is your ignition timing set at?
Old Mar 14, 2005 | 07:58 AM
dnbruut's Avatar
Default Re: emission problem on stock b16a2 (tgreaves)
no no you got me all wrong. my engine is stock with cai and open mufler and an afc set to zero. the readings i mentioned above where on a real exhaust gass emissions tester. and if i adjust the airfuel with my afc then co will rise.
annybody? thanks.
99_civic_si
Dec 28, 2005 02:30 PM
civilEX98
Feb 4, 2005 07:45 AM
civtic
Jan 14, 2004 02:37 PM
MikeMAN
12
Jun 20, 2003 06:48 PM
