ls sc61 peeps
Old Mar 13, 2005 | 06:55 AM
egvtec's Avatar
Default ls sc61 peeps
Whats up guys i just installed my sc61 on my ls and i ran first gear up to about 6000rpm at about 50% throttle. I didnt even see but about 1 psi of boost, Is this turbo this laggy? or do i possibly have a leak somewhere? I know i wont see boost till later on but it takes some effort to wake this thing up. im gonna go run it today and see how it does with the wideband hooked up. Either way all i need to do is get a clutch that will hold the power and i will post up a dyno im shootin for 400whp like i said i didnt gun it cause i still have to tune it im on a basemap. but running the gear up thre slowly didnt spool this thing but about 1psi at 6000 rpm
Old Mar 13, 2005 | 07:06 AM
alpha's Avatar
Default Re: ls sc61 peeps (egvtec)
First check for leaks. Then wait until you are fully tuned. BoostedCivicSedan would see three lbs in first gear with his LS coming off a light without problems.
Old Mar 13, 2005 | 07:23 AM
shermanyang's Avatar
Default Re: ls sc61 peeps (0x64)
what's the a/r on your turbine side? if it's a .63, don't expect to it to spool in first gear...especially with only half throttle.
even with my turbo, t3to4e .63/.60 60trim...i don't even get boost in first gear unless i gun it and take it to 8k on my ls. even then i only get about 5psi right as it hits 8k rpm. if you're trying to see how laggy it is, with an LS tranny start from 3rd gear at a 10mph roll or so and gun it. if you've got a GSR/B16/ITR tranny gun it from 4th. this is isn't the most accurate way to tell...but this is how we do it on the dyno.
Old Mar 13, 2005 | 08:48 AM
egvtec's Avatar
yeah its a .63 ar. is this thing gonna getup in third gear? i want it to be a highway beast
Old Mar 13, 2005 | 09:21 AM
D-meet07's Avatar
Default Re: (egvtec)
I'll beat that it will be a monster. I as well have the t3/t4 .63 ar and that thing threw me back in the seat. Imagining that u do have a much larger turbo...its gonna pull hard about 3rd gear and up
Old Mar 13, 2005 | 03:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egvtec &raquo;</TD></TR><TR><TD CLASS="quote">yeah its a .63 ar. is this thing gonna getup in third gear? i want it to be a highway beast</TD></TR></TABLE>
your 2nd and 3rd gears will be your best friends.
Old Mar 13, 2005 | 04:49 PM
egvtec's Avatar
so is this normal? it wont boost untill i give it full throttle?
Old Mar 13, 2005 | 04:58 PM
95GSRTT
Guest
Posts: n/a
boost is based on how much throttle you are giving it, not the rpm range. when Im driving on the highway going 75 mph at 3500 rpms Im still in vacuum. Its when I give it 100% throttle that it begins to actually boost
Old Mar 13, 2005 | 07:04 PM
tegon-gsr's Avatar
Default Re: (95GSRTT)
hey brad i just thought about it. this could be the problem it may be your intercooler why you are boosting a little late. your intercooler is so big. note sure but i here that it could make you spool a lil later. plus you were at half throttle as well just wait untill the tune you will be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">boost is based on how much throttle you are giving it, not the rpm range. when Im driving on the highway going 75 mph at 3500 rpms Im still in vacuum. Its when I give it 100% throttle that it begins to actually boost</TD></TR></TABLE>
^^^ exactly
Old Mar 13, 2005 | 07:08 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egvtec &raquo;</TD></TR><TR><TD CLASS="quote">yeah its a .63 ar. is this thing gonna getup in third gear? i want it to be a highway beast</TD></TR></TABLE>Trust me...from a proud owner of a LS-t (SC61 powered)...it will definitely be a highway beast. No more fears of American V8 muscleheads. LOL
Old Mar 13, 2005 | 07:30 PM
mrDFWmechanic's Avatar
beat some of thats dumbestics for me too
Old Mar 14, 2005 | 03:47 AM
Teglove2's Avatar
NVturbo...what's your setup. I didn't see you posted any dyno sheets/pics of your setup. Curious to see. Thanks.
Old Mar 14, 2005 | 06:24 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: (Teglove2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglove2 &raquo;</TD></TR><TR><TD CLASS="quote">NVturbo...what's your setup. I didn't see you posted any dyno sheets/pics of your setup. Curious to see. Thanks.</TD></TR></TABLE>
NO... THIS IS NOT MY "WISHLIST" BY THE WAY!!! LOL
B18b1 port-matched head
RS Machine iron-sleeved overbored B18A block (81.5mm)
Wiseco 9.3:1 cr pistons (was 8.8:1 cr)
Eagle H-beam rods (was Crower Econo-billet rods)
Cometics headgasket
ARP head studs
Precision SC61 (.63 A/R)
TIAL 38mm (set @ 1 bar)...hey Darius...that is 14.5psi since you suck at math! JK
RevHard die cast iron manifold
DSM 450cc injectors (Delphi 950cc are on the way)
Tyrus/Johnnyracecar.com FMIC
2.5" intercooler piping w/ silicone couplings
Aeromotive FPR
Walbro 255lph fuel pump
ACL bearings
balanced/polished crank
lightened/balanced OEM flywheel
ACT HD/SS clutch
KOYO aluminum radiator
HKS SSQV BOV
3" downpipe...full 3" exhaust system w/ Dynomax muffler
AEM cam gears
OEM Honda Type R oil pump
Prothane motor mounts
KYB AGX adj. shocks
Brembo cross-drill/slotted front rotors w/ VGX pads
H O N D A T A S200B
................FULL INTERIOR w/ stereo system
Sorry but no dyno sheet to post. Printer was down at time of dyno
331hp ~ 291tq tuned by MARK RILEY of TURBO TUNE (Greensboro, NC) I will be redyno-ing on MAR.25...will post up new dyno sheet after next dyno session.
Modified by NVturbo at 10:40 PM 3/14/2005
Old Mar 15, 2005 | 05:12 PM
D-meet07's Avatar
Default Re: (NVturbo)
NVturbo... When does that sc61 hit full boost?? Those are nice numbers
Old Mar 15, 2005 | 05:22 PM
D-meet07's Avatar
Default Re: (turbo90lude)
NVturbo....What stage sc61 are u running. I may consider selling my turbonetics and buying a sc61
Old Mar 15, 2005 | 07:29 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo90lude &raquo;</TD></TR><TR><TD CLASS="quote">NVturbo... When does that sc61 hit full boost?? Those are nice numbers</TD></TR></TABLE>Thanks...Before my "rebuilt", it hit full boost around close to 5500 rpm in 3rd and about 5800 rpm in 4th due to the fact that my compression was around 8.8:1 which had some turbo lag @ low end. The SC61 I am using is (turbine) .63 A/R and (compressor) is .60 A/R. Trust me the "61" will definitely make more power and torque than a comparable Turbonetics.
Old Mar 15, 2005 | 07:42 PM
s2kdre's Avatar
when i first put my sc61 on my ls, it was still automatic, and when i first drove the car it wasnt as quick as i thought it would be give the turbo at least a 100 miles and thats when it will be broken in. i get full boost at 4.8k, and now with my gsr tranny it feels like there is no lag.
Old Mar 15, 2005 | 07:56 PM
FredoSP's Avatar
boost is dependent on engine load, not throttle position, I can have 75% throttle and be @ 8000 rpm and still not boost
Old Mar 15, 2005 | 09:44 PM
95GSRTT
Guest
Posts: n/a
Default Re: (FredoSP)
Cant say I have ever been at 75% throttle and NOT boosted but whatever you say boss
Old Mar 16, 2005 | 12:47 AM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">Cant say I have ever been at 75% throttle and NOT boosted but whatever you say boss </TD></TR></TABLE>
I hope ur joking, boost is dependent on load, no load = no boost
Old Mar 16, 2005 | 01:42 AM
N20civicB18's Avatar
you could have boost at 50% throttle as long as you have a high load (maybe going up hill) With my old small .42 t3 it would boost up at 25% throttle after like first gear if there is a load on it and the RPMs are high egnough to push the amount of air to spin the turbine to create boost
Old Mar 16, 2005 | 07:55 AM
95GSRTT
Guest
Posts: n/a
I hope you have a sense of humor. Honestly I dont really care what you have to say. Im sure you are right on it being based on engine load, but Im saying I have never been at 75% throttle and NOT boosted. Maybe the wasnt enough for you to catch on. Got it now?
Old Mar 16, 2005 | 12:00 PM
Rod Short's Avatar
Look at the numbers scribed on the outlet of the compressor cover and let me know. You could have the wrong SC61 for your application. There are 3 versions with different turbins wheels sized to the engine displacement.
Old Mar 16, 2005 | 12:06 PM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">I hope you have a sense of humor. Honestly I dont really care what you have to say. Im sure you are right on it being based on engine load, but Im saying I have never been at 75% throttle and NOT boosted. Maybe the wasnt enough for you to catch on. Got it now?</TD></TR></TABLE>
Enjoy!
http://www.efi101.com/
http://www.amazon.com/exec/obi...07225
