water injection people
Old Mar 13, 2005 | 02:10 PM
morepoop4u's Avatar
Default water injection people
so i have this pressure switch
which terminal do i hook up to the 12v ignition and which to the #86 pole on the relay.
Old Mar 13, 2005 | 03:09 PM
mrbsponge's Avatar
looks as if the middle is the ground, and the top and bottom are the window, i mean 12 volts in the top and 12 coming out of the bottom
Old Mar 13, 2005 | 06:15 PM
morepoop4u's Avatar
Default Re: water injection people (morepoop4u)
bump
Old Mar 13, 2005 | 06:23 PM
Tony the Tiger's Avatar
"NC" is normally closed -- I assume the circuit will disconnect whenever the switch is active. Like an inverted trigger.
"NO" is normally open -- the circuit will probably connect to GND or 12v when the switch is active.
I guess try to wire it up to whatever you want the switch to do
Old Mar 13, 2005 | 07:57 PM
TunerToys's Avatar
Connect 12V positive to the COM connection.
Below the pressure level of the switch that same 12V will be available at the NC connection, and nothing will be availble at the NO connection.
When pressure goes above the trigger level of the switch, that 12V positive will be available at the NO connection, and will no longer be available at the NC connection.
If you want the water to spray when the manifold sees pressure above the trigger level of the switch, connect the switch in the following manner....
Positive supply -> fuse -> COM connection -> NO -> positive of water pump (red prolly) - pump to ground (black prolly).
You'll need to connect a tube between manifold vac/pressure and the switch.
Craig @ TunerToys
Old Mar 13, 2005 | 08:08 PM
Default Re: water injection people (TunerToys)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerToys &raquo;</TD></TR><TR><TD CLASS="quote">Connect 12V positive to the COM connection.
Positive supply -&gt; fuse -&gt; COM connection -&gt; NO -&gt; positive of water pump (red prolly) - pump to ground (black prolly).
Craig @ TunerToys</TD></TR></TABLE>
Can the switch withstand the current draw of the pump? What most people use these switches for are pull to ground trigger. I would rather have the switch trigger a relay (wither GND or 12v) instead of running full power through the switch and then to the pump. What's the specs on that switch?
Old Mar 13, 2005 | 11:35 PM
morepoop4u's Avatar
Default Re: water injection people (Tony the Tiger)
here's the specs on the switch http://cgi.ebay.com/ebaymotors...=WDVW
and this is the wi kit i'm trying to replicate http://www.snowperformance.net...n.pdf
Old Mar 14, 2005 | 12:39 PM
TunerToys's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">
Can the switch withstand the current draw of the pump? What most people use these switches for are pull to ground trigger. I would rather have the switch trigger a relay (wither GND or 12v) instead of running full power through the switch and then to the pump. What's the specs on that switch?</TD></TR></TABLE>
Good call! I wasn't thinkin deep enough into it. A connection description for arelay based circuit, will require a picture!
eBay description rates the switch to 10 amps. AS long as your pump is below that, you should be fine...
Old Mar 14, 2005 | 04:07 PM
morepoop4u's Avatar
here's the wiring diagram
i don't have the water solenoid so do i just connect the No3 to the #85 terminal on the relay and thats it?
jjos
Audio / Security / Video
Apr 26, 2016 02:09 PM
Dazer 1991
Aug 27, 2012 03:26 PM
Threads
11
Jun 28, 2006 04:52 PM
EeeJayEight
Dec 31, 2005 10:56 AM
sharkcohen
Apr 8, 2005 04:44 PM
