spark plug heat range and gap??
Old Mar 14, 2005 | 08:23 PM
mike93eh
Guest
Posts: n/a
Default spark plug heat range and gap??
i have a greddy turbo kit on my sohc at 7psi. im currently using stock plugs which are ngk zfr5f-11, should i go colder to 6 or 7? and what do i gap them at?
thanks!
Old Mar 14, 2005 | 08:35 PM
platinum00's Avatar
Default Re: spark plug heat range and gap?? (mike93eh)
ngk-bkr7e with .030 gap.
if you run more then 10 psi try .028 gap.
Old Mar 14, 2005 | 08:43 PM
mike93eh
Guest
Posts: n/a
why 2 steps colder though? 5 is stock on my d15.. just want to be absolutely sure.
Old Mar 14, 2005 | 08:50 PM
eMpAtHy's Avatar
Default Re: (mike93eh)
what is temp range on a stock h23?
im currently running bkre7-11 or something like that. i had the pze6 or something like that and they were too hot for me.
also, is a .044 gap fine if im running msd 6 and msd blaster
Old Mar 14, 2005 | 09:06 PM
oxSLEEPERxo's Avatar
Default Re: (eMpAtHy)
do a gap of .30
Old Mar 15, 2005 | 12:41 AM
s2kdre's Avatar
Default Re: (oxSLEEPERxo)
it depends what your set up is. I run 2 step colder gapped at .24 sometimes .28 you just have to try it out and see if the car idles right,
Old Mar 15, 2005 | 12:47 AM
96-EJ6 B18C's Avatar
I run ZFR6F-11's in my D with a .60 trim T3 at 14 psi and gap them at .032...i think 2 steps colder for a Greddy kit is way overkill. I'd just run 6's and gap them between .030 and .035.
Old Mar 15, 2005 | 02:18 PM
mike93eh
Guest
Posts: n/a
Default Re: (96-EJ6 B18C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C &raquo;</TD></TR><TR><TD CLASS="quote">I run ZFR6F-11's in my D with a .60 trim T3 at 14 psi and gap them at .032...i think 2 steps colder for a Greddy kit is way overkill. I'd just run 6's and gap them between .030 and .035. </TD></TR></TABLE>
yup thats what i decided on...
hondaeg8
Dec 8, 2004 08:18 PM
808b18c1boosted
Jan 16, 2004 11:11 AM
_Endless_
Nov 10, 2002 06:43 PM
TurbothisLS
Sep 9, 2002 12:39 PM
ImprtTuner88
Feb 26, 2002 10:15 AM
