turboedit please help
Old Mar 12, 2005 | 10:51 AM
honda06si's Avatar
Default turboedit please help
ok i am planning on using turboedit on my b16 turbo setup i have:
b16a1
pr3 ecu
aebs intake manifold
type r crank pulley
i will be running a t3 turbo on 8 psi
i am new to the chipping and burning stuff so i need help
http://cgi.ebay.com/ws/eBayISA...&rd=1
will this be able to program the chip?
also what chip do i need for the pr3? what number of pins is it?
if i am programming it myself, do i have to take the chip out of my pcm to make changes to it? does this mean i have to solder and resolder everytime?
also i have turboedit up and running on my pc... is there anything else i need besides a chip, burner, and the software?
what is ZIF?
thanks alot
Old Mar 12, 2005 | 12:15 PM
mrbsponge's Avatar
that should work fine, looks like th eenhanced wilhem burner to me, a ZIF is a type of socket that you plug ships into.
look on ebay they have chipping sets, with directions and all yo need. cost like 15 bux, just type in civic chip and it will come up, yo udont have to use the chip but you can use all the hardware.
as long as you have all the software off the internet, you should be fine, its definetley and experience
Old Mar 12, 2005 | 01:11 PM
DENCIO's Avatar
Default Re: (mrbsponge)
pm xenocron for chipping kit.. here's xeno's site..
http://xenocron.com/products.php?page=chippingkits
Old Mar 12, 2005 | 01:23 PM
honda06si's Avatar
if you use turboedit...i put the base map in for my pr3 ecu and it only goes to 7400 rmps..
also do i have to solder and resolder the chip everytime i want to make changes?
Old Mar 12, 2005 | 01:52 PM
ndogg's Avatar
Default Re: (honda90si)
no, you solder the ZIF socket in. ZIF == Zero Insertion Force, meaning you can drop in the chip and then push down the lever on the ZIF and it will lock the chip in. then when you burn an new chip, pull the lever up and switch them out.
this is a ZIF:
you should buy the "uberdata modification kit" it comes with everything you need to chip the ecu, including 1 programable chip and a ZIF, i would also get a few extra chips and their usb burner for ease of use.
uberdata kit: http://www.moates.net/product_...id=42
burner: http://www.moates.net/product_...id=48
edit: i don't know jack about obd0, so this may not be the right chipping kit.
Old Mar 12, 2005 | 03:29 PM
Boosted Chemist's Avatar
Default Re: turboedit please help (honda90si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda90si &raquo;</TD></TR><TR><TD CLASS="quote">ok i am planning on using turboedit on my b16 turbo setup i have:
b16a1
pr3 ecu
type r crank pulley
It will not work, that ebay map will work fine but if u want to use TE to modify your map you will run in a problem, PR3 maps arent supported for boost in TE (correct me if im wrong blundar) You will need to run a pm6 or ps9. A ps0 is an auto pm6 that is able to convert to a one wire vtec (zdyne eat your hearts out) will a simple ng 58 bin. Pm me if you are intrested in more info
ps. I would recomend buying Xenocrons chipping kits, a good straight foware guy
what is ZIF?
thanks alot</TD></TR></TABLE>
Old Mar 12, 2005 | 04:06 PM
honda06si's Avatar
Old Mar 12, 2005 | 04:41 PM
its the same chip taht c29 256 that everone sells, get ahold of xenocron
Old Mar 12, 2005 | 07:05 PM
honda06si's Avatar
Default Re: turboedit please help (Boosted Chemist)
oh btw i downloaded turboEDIT and i also downloaded the base map for the pr3 and it only goes to 7400 rpms on the data chart?!?!?
Old Mar 13, 2005 | 03:54 AM
u mean the pr3 map, no boost? you cannot covert that to boost. 7400 is the max rpm that the ecu uses to for a data value. after this it uses a linear factor and and just adjust by multiplying
Old Mar 13, 2005 | 03:58 AM
For the ulitmate site into chipping and honda ecu modification goto
http://www.pgmfi.org they also have a forum. Spend some time reading the libary and dont post basic **** in the forum because you will get flamed, my aim handle is CRXSIFUEL if u have any further questions im me and i will be glad to help.
x4code
Engine Management and Tuning
Jun 18, 2015 07:23 PM
JacobMagner
Jul 9, 2008 08:20 PM
jedsus
Apr 25, 2008 08:36 PM
fatpride111
10
Dec 27, 2007 05:17 PM
civperc
Jul 5, 2004 11:28 AM
