turbo?
Old Aug 6, 2005 | 03:30 PM
eatbieodie2's Avatar
Default turbo?
i just put a new mani on my car. and a new down pipe and i took it for a test drive and when im at full boost my car loses power. so when at full boost the rpm slows down if someone can help me it be great. thanks
Old Aug 6, 2005 | 04:00 PM
Blaze45's Avatar
Brrraaaap!
Default Re: turbo? (eatbieodie2)
Sounds like a boost leak, are you reaching full boost? You could have a massive exh. leak cause your turbo not to spool properly...
Old Aug 6, 2005 | 11:05 PM
Default Re: turbo? (Blaze45)
no i got full boost and i just got a new exs. system in. ?????
Old Aug 6, 2005 | 11:42 PM
Redline130's Avatar
What size is the piping of the exhaust system? If it's too small it could be hurting your performance.
Old Aug 7, 2005 | 08:50 PM
Default Re: turbo? (Redline130)
the pipping is 2.5
it feels like something eltrical or with the fule
Old Aug 7, 2005 | 09:03 PM
dc2legend's Avatar
You changed the whole exhaust setup. Get it tuned.
Old Aug 8, 2005 | 07:53 PM
Default Re: turbo? (dc2legend)
just asking why does it need to be tuned and should i get a apeix fuel svac .
thanks
Old Aug 8, 2005 | 08:57 PM
a1320addict's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2legend &raquo;</TD></TR><TR><TD CLASS="quote">You changed the whole exhaust setup. Get it tuned.</TD></TR></TABLE>
word
the diameter of your exhaust can greatly affect your tune...for instance
if you were tuned with a stock exhaust system and a standard t3/t4..lets say a 60 trim. the stock exhaust is causing a restriction, so when you get tuned it will only be creating so much boost in certain points of the powerband.
now...say with the same setup...you threw on a 3 inch, the turbo would be able to spool quicker...because of the free'd up exhaust...causing more boost earlier and in spots of the powerband that were only seeing so much boost with the stock system.
you would not be tuned - you would have a different powerband pretty much.
anytime you do anything "major" (ie. exhaust, downpipe, turbo, intake manifold, etc) to your engine after youve been tuned, you should retune.
goodluck
Old Aug 9, 2005 | 02:25 PM
Default Re: turbo? (yehiknowrite)
should i get a chip ecu or something
Old Aug 9, 2005 | 03:18 PM
go and visit some shops around you...speak with tuners there...see what program they like. then reseach what you want from your ems.
good luck..
check out neptune..uberdata..etc
Modified by yehiknowrite at 12:33 AM 8/10/2005
Old Aug 16, 2005 | 05:55 PM
i talk to the shops and they said it was something with my injector
Old Aug 18, 2005 | 12:19 AM
anyone ????????????????????
Old Aug 18, 2005 | 04:18 AM
delslo93's Avatar
Do you have an injector leak?....pull the fuel rail off and make sure the seals at the top of the injectors are still intact and not ripped. You also might wanna check timing?
Old Aug 19, 2005 | 12:59 PM
Default Re: turbo? (delslo93)
ok thanks
fro
Mar 11, 2005 11:53 PM
zseeanz
Feb 19, 2004 10:58 AM
hotboi850
Aug 30, 2003 08:59 AM
turboteg96
Apr 11, 2003 07:50 PM
GZERO
Dec 25, 2002 11:10 PM
