zeitronix wideband questions... just got done datalogging
official honda whore
well i hooked up everything and it datalogs a/f fine and it says my tps and user1 are the same thing basically, but waht i dont get is my user 1 input only goes up to 4.3 or 4.4 at wot .... and the tps reads 99 at wot, i was just wondering if thats right , or if i need to adjust my throttle cable because i thought it was supposed to go to 5 volts
also, is there any way to datalog boost w/o buying there boost feature, like could i hook it up to my stock map sensor, or my gm 3 bar???
besides these questions i absolutely love this wideband, no problems datalogging, just couldnt get em to work with uberdata 1.70?? idk why, i exited outta zeitronix program and set it to com1 and zeitronix wideband an all my readings were way wacked out of it
brian
ps had it all hooked up and datalogging withing 30 mins
brian
Re: zeitronix wideband questions... just got done datalogging (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer »</TD></TR><TR><TD CLASS="quote"> just couldnt get em to work with uberdata 1.70?? idk why, i exited outta zeitronix program and set it to com1 and zeitronix wideband an all my readings were way wacked out of it
brian
ps had it all hooked up and datalogging withing 30 mins </TD></TR></TABLE>
Last time I checked the Zeitronix wont work with Uberdata, Crome or Hondata. Since the voltage to AFR conversion (or whatever) is non-linear. Most other widebands like PLX and Innovate have a linear voltage to AFR output. So since it is non linear you can use a simple formula to tell you what each AFR to voltage ratio will be.
brian
Re: zeitronix wideband questions... just got done datalogging (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow »</TD></TR><TR><TD CLASS="quote">
Last time I checked the Zeitronix wont work with Uberdata, Crome or Hondata. Since the voltage to AFR conversion (or whatever) is non-linear. Most other widebands like PLX and Innovate have a linear voltage to AFR output. So since it is non linear you can use a simple formula to tell you what each AFR to voltage ratio will be.</TD></TR></TABLE>
ya i noticed that, oh well not a huge deal, i just didnt know if anyone out there had a fix for this for uber or not
bump
bump
bigwig was working on it, but I dont know if he finished it or not. Maybe you can ask him and see how he's doing on getting the Zt2 to work with UD.
Re: zeitronix wideband questions... just got done datalogging (Mikes01GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikes01GSR »</TD></TR><TR><TD CLASS="quote">I know neptune logger now supports it, I PMed james on his site yesterday.</TD></TR></TABLE>
ya i am waitin for neptune to come out for final user tuning, but for now uber is workin for me
btw, you ever go to pittraceway? i saw your car at westchester meet last year and would love to see it again
I don't head to the drags to often, I went once last year. It's sorta useless untill
I get slicks and I can't get them till I can get 15" wheels and I can't get them
until I figure out how to get them over my 12.2" brakes so it's a viscous cycle.
Next year you could come to beaver run and check it out or one of our pittsburgh
meets depending on how close you are.
I just hooked my User 1 input to the Map Sensor wire coming from my ecu. I then convert the Volts to Psi. Yeah it won't work with the Uberdata so I just use the Zeitronix Software and tune from there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikes01GSR »</TD></TR><TR><TD CLASS="quote">I don't head to the drags to often, I went once last year. It's sorta useless untill
meets depending on how close you are. </TD></TR></TABLE>
ya im living in indiana right now, been on pittspeed alot an been to pittraceway a cpl weeks in a row now
i remember awhile back because your big brake kit that you need to run atleast 16" WHEELS or something, oh well i guess braking is a priority before the 1/4
i remember awhile back because your big brake kit that you need to run atleast 16" WHEELS or something, oh well i guess braking is a priority before the 1/4</TD></TR></TABLE>
Yeah when road course is more of a priority then drag racing brakes are a big deal.
Re: (SynTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SynTeg »</TD></TR><TR><TD CLASS="quote">I just hooked my User 1 input to the Map Sensor wire coming from my ecu. I then convert the Volts to Psi. Yeah it won't work with the Uberdata so I just use the Zeitronix Software and tune from there. </TD></TR></TABLE>thats what I did on on mine
Re: (ramennoodles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramennoodles »</TD></TR><TR><TD CLASS="quote">thats what I did on on mine</TD></TR></TABLE>
whats the conversion you guys use to convert it to? and do you wire up all 3 wires from the map sensor, or just one, also if someone could tell me the pin out for the ecu id appreciate it
brian
brian
Re: (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow »</TD></TR><TR><TD CLASS="quote">Check out this thread
https://honda-tech.com/zerothread?id=1033455</TD></TR></TABLE>
ya thats the write up i used, but i still dont know the conversion factor to be able to read the amount of boost or what else i need to hook up if possible to be able to datalog boost w/o buying the sensor from zeitronix
this is what i use
and this one in excel http://www.google.com/url?sa=t...2qOsM
Re: zeitronix wideband questions... just got done datalogging (ramennoodles)
stock is 1.75 thoughh, wo these charts dont help me any
Re: (93turbo16)
I thought you said your using gm 3bar. thats why I posted. sorry. you could always just add the 3bar in, feed it 5v, ground and send the signal wire to the user input on the zeitronix
Kidd_Stylez
11-02-2004 04:14 PM
