Coolant Leak Between Head and Block
Old Aug 7, 2005 | 07:21 AM
Rhythm's Avatar
Default Coolant Leak Between Head and Block
I just found a leak on my car and wanted to get some opinions. I've got a LS turbo with a built bottom end and ARP head studs. There's some coolant that seems to be coming from between the head and block, primarily on the tranny side of the motor. The engine was running great, no smoking or overheating, but I did lose some coolant.
Could it be that I just need to retorque the head studs (have not done this yet with about 600 miles since I rebuilt the motor) or could it be the headgasket? The oil looks fine, but there are some signs of oil in the coolant (small amounts of "cloudiness" in overflow tank and under the radiatior cap).
I've searched, but I haven't read about a case like mine where there is leaking on the outside of the motor.
Please help if you can. TIA
Old Aug 7, 2005 | 10:54 AM
Muckman's Avatar
Moderator in Chief
Default Re: Coolant Leak Between Head and Block (Rhythm)
Sounds like your head studs are a little loose. Try retorquing the nuts and the studs.
Old Aug 7, 2005 | 11:04 AM
Rhythm's Avatar
Thanks for the repsonse... I think I'm going to try that tonight.
Any other opinions?
Old Aug 7, 2005 | 11:37 AM
Muckman's Avatar
Moderator in Chief
Default Re: (Rhythm)
Compression test and hope your headgasket isnt blown.
Old Aug 7, 2005 | 05:13 PM
earl's Avatar
Default Re: (Muckman)
You may have used the wrong head gasket if it is a vtec head.
Old Aug 7, 2005 | 05:48 PM
Rhythm's Avatar
Thanks for the feedback... I won't get to it till tomorrow, but I'll update the thread for anyone that is seeing the same problem.
BTW, it's just an LS head, no vtec.
Old Aug 7, 2005 | 09:42 PM
earl's Avatar
Are you positive you used an ls gasket? I'm just guessing but if the leak is really between the head and the block, that usually is the problem.
OH_1fstgsr
14
Jul 21, 2008 06:03 PM
blackeg
Mar 30, 2006 02:49 PM
Aphelion
14
Dec 31, 2005 01:00 PM
b_serious
Dec 1, 2005 10:08 AM
CM-R
Apr 10, 2003 09:48 PM
