Do my plugs look ok?
Old Aug 7, 2005 | 07:08 PM
fanta!'s Avatar
Default Do my plugs look ok?
Are my plugs ok? Click the pictures for bigger view
http://www.flickr.com/photos/19784966@N00/32147469/
http://www.flickr.com/photos/19784966@N00/32147468/
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: Do my plugs look ok? (fanta!)
You're rich, bitch!
Old Aug 7, 2005 | 07:32 PM
Dunc's Avatar
BCICAN
Default Re: Do my plugs look ok? (boostincoupe)
really really rich
Old Aug 7, 2005 | 09:31 PM
ash.zero's Avatar
carbon build up fo sho.
Old Aug 7, 2005 | 09:33 PM
SHystrdyGSRtdy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">You're rich, bitch!
lol
Old Aug 7, 2005 | 11:14 PM
fanta!'s Avatar
Default Re: Do my plugs look ok? (SHystrdyGSRtdy)
ive had them in for a while could that of factored anything? or would i still be running rich regardless
Old Aug 7, 2005 | 11:18 PM
hondaeg8's Avatar
damn.. thats ****** rich
Old Aug 8, 2005 | 02:04 AM
Tad's Avatar
Tad
Default Re: Do my plugs look ok? (hondaeg8)
do a full throttle run to almost redline and shut your car off at that point.
without revving down or anything, just shut it off, and coast to the side of the road.
pull ur plugs, take a pic of them and post it.
that'll give a good idea of how your engine is running.
what this tells us is that under your normal driving conditions, combined,
you're running pretty rich.
But i've seen worse,
I had an overly cammed sohc setup and my plugs were JET BLACK,
i mean no color whatsoever. I see at least some brown on your plugs.. so they arent completely coated, haha.
Old Aug 8, 2005 | 06:48 AM
fanta!'s Avatar
Default Re: Do my plugs look ok? (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">do a full throttle run to almost redline and shut your car off at that point.
i mean no color whatsoever. I see at least some brown on your plugs.. so they arent completely coated, haha.</TD></TR></TABLE>
yeah these were taking out after they were idiling for a bit
Old Aug 8, 2005 | 02:11 PM
i think the point is to NOT let them idle.. as in, take them out immediately after the run
Old Aug 8, 2005 | 04:00 PM
s2kdre's Avatar
rich
Old Aug 8, 2005 | 06:29 PM
fanta!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">i think the point is to NOT let them idle.. as in, take them out immediately after the run</TD></TR></TABLE>
yea i know...
Old Aug 8, 2005 | 06:30 PM
coupon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">rich </TD></TR></TABLE>
i think thats already been said
Old Aug 8, 2005 | 08:46 PM
SOHCD16y8's Avatar
im gonna go ahead and take a shot in the dark here, but I think your running a little rich. Let us know how they look after a full throttle run
Old Aug 8, 2005 | 09:25 PM
mike93eh
Guest
Posts: n/a
looks like on a couple of them you need to go a step colder...
need better pics
Old Aug 8, 2005 | 09:37 PM
Default Re: (mike93eh)
look on the bright side, at least you're not running too lean
Old Aug 10, 2005 | 12:49 PM
fanta!'s Avatar
Default Re: (SHystrdyGSRtdy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">looks like on a couple of them you need to go a step colder...
need better pics</TD></TR></TABLE>
they are bkr7e's. the stock heat range on my h22 is 6, so should i get some 8's?
Old Aug 10, 2005 | 01:28 PM
DRAGLS's Avatar
Default Re: (fanta!)
Actually the plugs are at the right heat range from the pics, BUThe really won't know until he does a wot pull and checks his plugs.
Old Aug 10, 2005 | 01:34 PM
PM-Performance's Avatar
I think that will really only serve for checking for detonation.
How rich will it run at idle? If you keep it in closed loop it should correct itself to stoich.
Also even on new plugs it wont show. That takes time to burn like that on plugs.
Doing a pull and shutting it off on those plugs will look exactly the same.
They are black and will remain black.
Get on a wideband and cut the guessing.
Old Aug 10, 2005 | 04:13 PM
Under_Pressure's Avatar
Default Re: Do my plugs look ok? (itr206)
thats what my plugs look like Fmu's do that i guess
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fanta! &raquo;</TD></TR><TR><TD CLASS="quote">
they are bkr7e's. the stock heat range on my h22 is 6, so should i get some 8's?</TD></TR></TABLE> I use ZFR7F-11 should i change to bkr's?? 7 psi on a h22.
EngineNoO9
Honda Motorcycles
13
Nov 8, 2008 07:05 AM
J.nguyen
Sep 23, 2006 01:07 PM
budget
Apr 28, 2005 11:04 AM
TurblowR
Dec 5, 2004 02:26 PM
boost fed ls
Nov 29, 2003 12:02 PM
