Compression numbers - how do they look
Old Aug 8, 2005 | 06:40 AM
ginoboy1978's Avatar
Default Compression numbers - how do they look
Engine: D16Y8
Hey guys, just want some feedback on these numbers. Basically i took two runs for each cylinder, just to confirm my numbers. Cranked it 5 times both times. Cylinder 1 being on the right, and cylinder 4 on the left. So here it is:
Cylinder 1- 165psi, 160psi
Cylinder 2- 165psi, 170psi
Cylinder 3- 170psi, 180psi
Cylinder 4- 185psi, 180psi
Please advise, thanks guys.
DAN
Old Aug 8, 2005 | 07:32 AM
Dunc's Avatar
BCICAN
Default Re: Compression numbers - how do they look (ginoboy1978)
The difference between your high and low numbers is about 11%. That seems to be a little much, but it's not too terribly bad.
And for a side note... nice avatar
Old Aug 8, 2005 | 07:39 AM
ophdehEEEzy's Avatar
hmm..
Old Aug 8, 2005 | 08:36 AM
Rod.'s Avatar
Default Re: Compression numbers - how do they look (OH ISH ITS DAT FOOL JAMES)
hmm will that avatar be taken away
Default Re: Compression numbers - how do they look (Dunc)
Thanks man. You think it would be safe to turbo the engine?
Thanks about the avatar too.
DAN
Old Aug 8, 2005 | 08:37 AM
Default Re: Compression numbers - how do they look (Rod.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rod. &raquo;</TD></TR><TR><TD CLASS="quote">hmm will that avatar be taken away</TD></TR></TABLE>
Why........it's just a woman's hand on a computer mouse?
DAN
Old Aug 8, 2005 | 09:13 AM
MikeMAN's Avatar
did you hold the throttle open while doing this?
Old Aug 8, 2005 | 09:36 AM
Default Re: Compression numbers - how do they look (MikeMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">did you hold the throttle open while doing this?
This is my buddy's car.
Yes I did Mike. Held the gas pedal down and cranked the engine 5 times.
DAN
Old Aug 8, 2005 | 09:39 AM
Rod.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ginoboy1978 &raquo;</TD></TR><TR><TD CLASS="quote">
DAN</TD></TR></TABLE>
for real...haha...it tricked me....looks like something else
you could turbo it...those d-series are a dime a dozen
Old Aug 8, 2005 | 09:43 AM
Dunc's Avatar
BCICAN
It definitely fooled me, I was like "what? a computer mouse....OOOOH MY GOD HAHAHA"
Old Aug 8, 2005 | 10:55 AM
Yeah its a good illusion..
So does anyone have anymore opinions about the compression test numbers?
DAN
Old Aug 8, 2005 | 11:04 AM
Mase's Avatar
crank more the 5 times, crank each cylinder 5 times until the needle on the compression gauge stops moving
Old Aug 9, 2005 | 07:00 AM
Default Re: Compression numbers - how do they look (Mase)
Thanks guys, i'll advise him.
DAN
Old Aug 9, 2005 | 12:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">crank more the 5 times, crank each cylinder 5 times until the needle on the compression gauge stops moving</TD></TR></TABLE>
Mase my buddy just did his test again today, this time cranking it until the needle stopped. Numbers came out alot better:
190/190/185/195
Thanks bud.
DAN
Jyankel
Oct 23, 2016 05:27 PM
7rrivera7
Aug 30, 2007 09:24 AM
Its me DUB
Apr 2, 2005 11:59 PM
opiumdaze
Mar 30, 2005 04:25 PM
