Remote IACV?
Old Aug 5, 2005 | 10:35 PM
wantboost's Avatar
Who is Mr Robot?
Default Remote IACV?
Ok, i;ve been thinking about it and i think it will work, my intake mani doesnt have any provision for the factory IACV. There is a fitting on the tb that i could lead to one side of the IACV and then therea rea few ports on the back of the intake mani..
will it work?
you can see the fitting capped off on the bottom
the back of the mani (if you didnt notice )
Old Aug 5, 2005 | 10:57 PM
cubish's Avatar
Default Re: Remote IACV? (wantboost)
just use 2 of the 48749757595 you have coming off the intake mani and run them to a plate. tap some push on fittings to the plate and secure the plate to the sensor. should be fine. as long as the sensor is reading whats goin on in the mani you are in good shape
Old Aug 5, 2005 | 11:03 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Remote IACV? (cubish)
lol. im using the aem ems so i would like the iacv to actually function, thats why i wanted to use the port at the tb then the one on the back of the intake mani.
Old Aug 6, 2005 | 05:17 AM
wantboost's Avatar
Who is Mr Robot?
anyone?
Old Aug 6, 2005 | 12:05 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Remote IACV? (boostedcivicsir)
yea its a mustang tb. that bottom nipple isnt a coolant port, it just leads directly into the tb inlet
Old Aug 6, 2005 | 12:45 PM
raene's Avatar
Yes it should work!
Old Aug 6, 2005 | 12:59 PM
KStuned's Avatar
Default Re: Remote IACV? (raene)
It will work, ... but you must install one of the ports to the manifold side (after the throttle plate) and the other to the charge pipe side (before the throttle plate). The IAC just regulates how much air can enter the intake manifold with the throttle plate closed. Hooking both of the ports on the IAC to the intake manifold side will not work, as it will not be bypassing any air around the throttle plate.
We are doing a similar remote IAC on a custom manifold Talon.... works fine.
Old Aug 6, 2005 | 01:07 PM
JDM-Civic-Hatch's Avatar
yeah, isnt coolant supposed to go into the intake??!!!!
DURRR. Geeessssss....
-Chris
Old Aug 6, 2005 | 02:19 PM
D-tuned's Avatar
Default Re: Remote IACV? (JDM-Civic-Hatch)
since your using a mustang T/B just use a mustang IACV. I did, it works great. the idle settings in the AEM will be like setting up the stock one.
Old Aug 6, 2005 | 03:39 PM
DaveF's Avatar
Default Re: Remote IACV? (Hondaddict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaddict &raquo;</TD></TR><TR><TD CLASS="quote">It will work, ... but you must install one of the ports to the manifold side (after the throttle plate) and the other to the charge pipe side (before the throttle plate). The IAC just regulates how much air can enter the intake manifold with the throttle plate closed. Hooking both of the ports on the IAC to the intake manifold side will not work, as it will not be bypassing any air around the throttle plate.
We are doing a similar remote IAC on a custom manifold Talon.... works fine. </TD></TR></TABLE>
thank god for this post
it simply amazes me, that some people do not know how the iac works
Old Aug 6, 2005 | 04:15 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Remote IACV? (Dturbocivic)
yea i knew how it worked and how to route it, just wanted feedback on it. the reason i am using the stock iacv is my car is obd2 and i have to go through the ecu code check, so im pretty sure a mustang iacv will throw a code.... now for that damn mustang tps, lol
Old Aug 6, 2005 | 04:55 PM
.dave's Avatar
i HAS questions ?
WTF? ECU code check? Theres no way you're running the stock ECU with all the **** you're doing.
Old Aug 6, 2005 | 06:52 PM
D-tuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">yea i knew how it worked and how to route it, just wanted feedback on it. the reason i am using the stock iacv is my car is obd2 and i have to go through the ecu code check, so im pretty sure a mustang iacv will throw a code.... now for that damn mustang tps, lol</TD></TR></TABLE>
the tps is nothing to get working. it takes about 2 minutes if unless your slow
Old Aug 6, 2005 | 08:47 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Remote IACV? (D-tuned)
lol. im gonna have to put my stock ecu and injectors back in and pull the wg to pass emissions. i have my stock map sensor, but im owndering how i can rig the stock honda tps up for emissions purposes only. I do have the ability to register my car as a dealer with ga but i dont know if that emits me from emissions
Old Aug 7, 2005 | 06:15 AM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">lol. im gonna have to put my stock ecu and injectors back in and pull the wg to pass emissions. i have my stock map sensor, but im owndering how i can rig the stock honda tps up for emissions purposes only. I do have the ability to register my car as a dealer with ga but i dont know if that emits me from emissions</TD></TR></TABLE>
Lame. I'm assuming they plug into the OBD2 port on cars for inspection now in Georgia too? Just have someone with the same car (doesn't even have to be the same year) get inspected for you with your registration. Then just enter all your information on the states computer system. You just have to find a shady inspection place where the employees are ok with that.
Old Aug 7, 2005 | 06:22 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Remote IACV? (daveG)
yup and they scan the barcode on the door automatically puts everything up on the screen
i have thought of just making a duplicate sticker. hehe
the problem is all of the inspection places are in town and are full of rednecks (i.e your civic needs to be destroyed) so finding one that will help me out could be a little hard,
Old Aug 7, 2005 | 06:30 AM
.dave's Avatar
i HAS questions ?
That blows. Bring both cars, then plug into the other one. Either that or say **** it and pick up a 92-95 hatch.
Old Aug 7, 2005 | 09:11 AM
wantboost's Avatar
Who is Mr Robot?
i have thought about doing that. i found a killer price on a shell that was complete minus motor
ef-hatchcrap
Apr 19, 2008 07:33 AM
mistahmac
Jul 17, 2007 11:43 PM
VTECorona
Aug 17, 2002 11:51 AM
