boost on my t3 int wastegate is only getting to 3 psi?? need help
boost on my t3 int wastegate is only getting to 3 psi?? need help. i checked all my pipes from the comp housing to the intake mani and no leaks detected. i feel some out of the bov but when i give it gas it goes away..
Re: boost on my t3 int wastegate is only getting to 3 psi?? need help (hondaguyexsi)
i found a extra tapped hole in the compressor housing but not sure if that will filter that much boost
i think i have a shitty wastegate. i unpluged it and drove carefully and it got to 10 psi in notime
Re: (epic1si)
its your internal wastegate.I bet the spring inside is worn out. Same thing happened to me on my t3. It was only boosting like 2-3, so im using a boost controller to regulate the boost. My internal waste spikes alot, so ill be converting to external soon.
Re: (xtremeazian)
my wastegate has an adjustment on the actuator im gonna try tightening and loosening it. but my gate ia prolly junk
