overheating in hot weather
Old Aug 5, 2005 | 11:06 AM
97dc2's Avatar
Default overheating in hot weather
i just moved to palm springs and my car overheats even at night when its 90 degrees. Back at home in los angeles it would only overheat when i was flying on the freeway. how can i fix this prob.
Old Aug 5, 2005 | 11:33 AM
mike1114's Avatar
Default Re: overheating in hot weather (97dc2)
"Common over heat problems
T-Stat---usually it is because of this piece of **** that you overheat.
Bubbles in cooling system. 2nd biggest reason, you didn't bleed enough, you have to leave the car idling for like a half hour to get all the bubbles out with the heater on.
Rad Cap is bad--wont hold pressure.
Leaking coolant somewhere---this can happen only at WOT and not at idle so its hard to find sometimes.
Make sure you fan is coming on. I wired mine to stay on always when car is on.
Worst case scenario is headgasket is leaking exhaust gas into coolant system. You can sometimes see this if you look in your rad resevior and see bubbles coming up."
Oh and by the way, this topic is covered like every day so.......
Old Aug 5, 2005 | 11:49 AM
Rufus523's Avatar
The fluidyne radiator really helped a lot on my car, but it is a half rad. If you are talking about the integra in your avatar then that radiator stock should be big enough.
Now my temps only barely climb when it is REALLY hot or <humid>. But the fact is that they still want to climb. I always see pictures of people with big time setups with the stock half radiators! God bless them, I just can't understand how they get away with it. Good luck.
Old Aug 5, 2005 | 11:57 AM
ginoboy1978's Avatar
"when flying on the highway" - usually thats when the car is NOT supposed to overheat.
Maybe your theromstat is toast, or your fan is not in perfect working order.
DAN
Old Aug 5, 2005 | 12:03 PM
EgLsTurbo's Avatar
Default Re: overheating in hot weather (ginoboy1978)
wat if your theromstat is toast alot of ppl run without a theromstat.
Old Aug 5, 2005 | 12:13 PM
Rufus523's Avatar
Default Re: overheating in hot weather (EgLsTurbo)
I did not think was good advice in a honda (removing the thermostat). Something about the car not reaching operating temperature as quickly and then slowly overheating....somebody correct me if I am off base here.
Old Aug 5, 2005 | 12:37 PM
mike1114's Avatar
Default Re: overheating in hot weather (Rufus523)
DO NOT remove the t-stat, your car will overheat faster if you do.
Seriously, overheating comes from one of the things I listed above.
Start on that list, from top to bottom, checking all I said, you'll find the culprit.
And as said, definitely get a fluidyne, koyo or some aluminum, thicker rad than stock. I also run an oil cooler on my daily driver.
Old Aug 5, 2005 | 03:33 PM
FAUCON's Avatar
https://honda-tech.com/zero...age=1
Old Aug 7, 2005 | 12:37 PM
97dc2's Avatar
Default Re: (FAUCON)
i just got my car tuned. i have a new mugen termostat, and new aftermarket aluminum radiator.
Old Aug 7, 2005 | 01:42 PM
Muckman's Avatar
Moderator in Chief
Default Re: overheating in hot weather (mike1114)
Mike and I love these overheating threads lol
Old Aug 7, 2005 | 02:21 PM
mike1114's Avatar
Default Re: overheating in hot weather (Muckman)
LeArN2LiVe
Nov 22, 2008 12:08 PM
Fighterinsnatch
11
May 21, 2007 02:43 PM
zoolander
11
Feb 14, 2006 07:38 AM
hotinteggy
Sep 16, 2005 06:01 PM
xSCTYGx
Apr 30, 2004 10:31 PM
