Ostrich help
Old Aug 7, 2005 | 06:28 PM
SOHCD16y8's Avatar
Default Ostrich help
Can someone explain to me in detail how to install the ostrich on my chipped P75, it has a zif socket on it. I have everything loaded and hooked up but when I hit black check it says error and will not work. And the car starts and runs fine like nothing is loaded at all. Im a dumbass with computers so any help or links would be great. Dont say post on the uber forums because I did and searched but no help yet. Thanks
Old Aug 7, 2005 | 07:11 PM
SOHCD16y8's Avatar
anyone?
Old Aug 7, 2005 | 07:25 PM
BlueShadow's Avatar
Default Re: (SOHCD16y8)
http://uberdata.pgmfi.org/foru...=2402
Old Aug 7, 2005 | 08:27 PM
SOHCD16y8's Avatar
Default Re: (BlueShadow)
been there still says incorrect version HELP
Old Aug 7, 2005 | 08:29 PM
BlueShadow's Avatar
Did you read through the whole thread? if you are using UD1.7 or 1.7ost and it gives you the incorrect version error you need to change your firmware version.
Old Aug 7, 2005 | 08:33 PM
SOHCD16y8's Avatar
When I go to change my firmware it does not see the ostrich
SOHCD16y8's Avatar
How can I fix this?
Old Aug 7, 2005 | 08:41 PM
BlueShadow's Avatar
what version of uberdata are you using?
Old Aug 7, 2005 | 08:42 PM
SOHCD16y8's Avatar
I tried 1.7 ost and 1.8? Im so lost right now
Old Aug 7, 2005 | 08:51 PM
BlueShadow's Avatar
http://www.moates.net/document...id=22
download the firmware updater to your laptop which you are trying to run the Ostrich off of. Unzip it and run it and it will tell you what firmware version you have. To get UD 1.7Ost2 to work with the Ostrich you need to load firmware version 10.3.A. Download that too from the link above and unzip it. Then from your firmware updater click on the button on the middle right side with the three periods ... the browse to the 10.3.A file you unzipped. Once you have found it load it up and then in your firmware updater click on UPDATE.
Old Aug 8, 2005 | 02:17 PM
juiced2ndgenteg's Avatar
your firmware was corrupted when downloaded. same thing happend to me, call craig and he'll fix it for free. All you'll have to do is ship it to him.
jdmc0upe
Mar 17, 2008 09:09 PM
diznikkajebus
Jul 5, 2007 07:42 PM
ezyssi
Aug 10, 2003 11:51 AM
