where to get AEM regulator vacuum fitting???? damn help!
where can i get a new vacuum fitting for my AEM regulator, dont ask me how i lost mine, but i have been to every hardware store in the world and even asked AEM and they were like WTF how did that happen, right now i threaded in a piece of plastic but im worried about it
this piece
this piece
Re: where to get AEM regulator vacuum fitting???? damn help! (mrbsponge)
Pull the cap off and then drill the hole oversized and tap it 1/8 npt. Then you have a good selection of nipples and other fittings you can use as well as using a decent sized vacuum line. This is what I did to my SX regulator as it also had a very small fittng that seemed to be 1/16th npt.
Re: (mrbsponge)
The smallest NPT size that I could find on McMaster is 1/8". You can buy a 1/16" NPT to 1/8" barb fitting from Aeromotive. It's part number 15630. Check this link here:
http://www.aeromotiveinc.com/p...pters
I don't think there are too many other choices. You might not even need to tap it, just drill a hole and screw it in, then take it back out again and use teflon tape. Just don't tighten it in far enough to bind the spring.
BoOsTiN Dc2
09-16-2010 01:34 PM
asubennett
09-21-2004 04:50 PM
