WASTEGATE HELP URGENT (VACUM LINES*?)
ok look here all you nite hawks...i need urgent help concerning the ext. wastegate seeing as how i go pick up my car from the muffler shop tomorrow morning after there done with the down pipe.... here's the question and the specs... 96' GSR/B20...T3/T4, External wastegate, GReddy Pro-fec e-01 (EBC)... now i see 2 VACUM lines on the wastegate and i know that the top vacum line is for my e-01 EBC but where EXACTLY do i hook up the #2 vacum located near the base of the wastegate i already have the boost controller's PRESSURE SENCOR "T'd" into the Fuel Pressure Regulator as it says in the instructions... http://greddy.com/ __Tech/e-01__but then it says to connect the secound line into the turbo itself (which i have no connection point on my turbo) or to a "ALTERNATE PRESSURE SOURCE<U></U>" now...where is this ALTERNATE PRESSURE SOURCE...*!?! -swift
Mr. Badwrench
Re: WASTEGATE HELP URGENT (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">the intake manifold</TD></TR></TABLE>
this will work but you will get a correct boost reading if you drill the turbo with a 21/64ths bit and tap it with an 1/8 NPT and put a nipple in the snail. thats what i do on all my installs. i will be doin it to my brand new t3/t67
the drilling and all sounds like the best idea but im not too much of a handy man... so then which vacume line in/on the intake manifold should i then "T" the line off onto...?
ok i think ill tap into the brake booster...sounds good to me, thanks for the idea...now when hooking up the BOV...which vacum line should i use and where is it located?-swift
Modified by gsr_b20x2 at 11:33 PM 8/8/2005
Re: WASTEGATE HELP URGENT (playboyace35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playboyace35 »</TD></TR><TR><TD CLASS="quote">i t-ed mine off to the one on top of da intake manifold, near the right</TD></TR></TABLE>
which did you T off...the wastegate or ur BOV...?
Re: WASTEGATE HELP URGENT (gsr_b20x2)
imma pm u my number, i get off at 12, i'll pop my hood up and tell u.
cuz i dont remember it by memory, or u can hit me up on aim: playboyace35, up to u
ok kewl...ill get at you on aim tomorrow... my sn is breadofspam also all...if you guys have a chance...check out my other issue...maybe you can help... https://honda-tech.com/zerothread?id=1333977 thx you guys -swift
GeorgeJetson
06-12-2003 12:58 PM
