which sc61
Old Aug 6, 2005 | 04:33 AM
sluggo's Avatar
Default which sc61
I want to use a sc61 but im trying to decide which frame sc61 I am trying to make 530hp with a decent spool time ,I was looking at the sc6152e or should I go with the sc6169e and wondering the spool difference between the 2. Here is my setup
84mm b16
crower rods
rlz engineering head
cp pistons 9:1
gsr cams
full-race top mount t/3
Old Aug 6, 2005 | 05:03 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: which sc61 (sluggo)
sc6152e is what I always use...
Old Aug 6, 2005 | 06:44 AM
sluggo's Avatar
what kind of power are u making around 15psi and when are u hittin full boost and do you recommend the s housing or is is not worth the extra money
Old Aug 6, 2005 | 10:20 AM
lodo1's Avatar
i'm rockin the 6152e. works great for my stock b16. full boost at 5300 rpm.
Old Aug 6, 2005 | 10:50 AM
sluggo's Avatar
what kind of power are u makin at 15psi
Old Aug 6, 2005 | 10:56 AM
lodo1's Avatar
ohh i'm only runnin 7 right now, i'll run 10 after i dyno on monday.
Old Aug 6, 2005 | 11:01 AM
sluggo's Avatar
does it hit really hard at full boost and what kind of numbers are u expecting
Old Aug 6, 2005 | 04:41 PM
lodo1's Avatar
ohh man, when it hits, its just crazy. tires spin out like no other. i can see it doing 250 range on 7 psi, and very close to 300 on 10 psi.
91 DA Revived
May 19, 2012 04:11 PM
ITRBOY1433
Oct 10, 2008 03:54 PM
Themouse
Oct 8, 2007 02:47 PM
mikeycivic
May 25, 2007 05:35 AM
4ghatch
Apr 7, 2005 11:02 AM
