HELP with uberdata...
Old Aug 8, 2005 | 03:16 PM
importnoodles's Avatar
Default HELP with uberdata...
Ok so like, i just got my moates burn1 and tried to create a basemap so that i could just drive around. Ive tried all the stock bins but none of them seem to even work. The car just starts and then dies. If i step on the gas when it starts then it will rev but only up to 3500, when i let go of the gas then it dies. I cant turn off the full throttle launch it seems. For some reason i can't seem to get uberdata to do what i want it to. Can anyone give me a basemap that will allow me to drive my car while it's still stock?
Old Aug 8, 2005 | 03:55 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: HELP with uberdata... (importnoodles)
you best bet is to go to ..... http://uberdata.pgmfi.org/forum/
ask there and you shall recieve, also alot of people on here are very knowledgable about this, you sure you have a good .bin??? what version you running etc?
Old Aug 8, 2005 | 04:39 PM
SOHCD16y8's Avatar
I have the smae proplem and would like to know the answer
Old Aug 8, 2005 | 04:51 PM
hondaguyef's Avatar
Default Re: (SOHCD16y8)
If you've tried every .bin and none of them work it's not UD's fault. You are not doing something right and it's what I would call, "a bad burn". Please post the chip # that you are using and the method in which you are loading the .bin into the Flash & burn software. I may be able to help.
Phil
Old Aug 8, 2005 | 04:56 PM
BlueShadow's Avatar
Are you following the how-to make a basemap tutorial?
http://uberdata.pgmfi.org/foru...d=114
If you follow the instructions then you shouldn't have a problem saving the .bin. The Moates BURN1 also comes with really good instructions. If you followed it for your BURN1 driver install and then for how to use it, then it should work ok. Maybe you need to write down exactly how you make your basemap and how you use your burn1. Write everything, right down to exactly how you name the file (ie basemap or basemap.bin ) and the order that you open the flash and burn software and all that. Also it might help if people knew what type of engine you have.
Old Aug 8, 2005 | 06:04 PM
Okay well i got my ecu to work.... Guess it was my fault all along..
SOHCD16y8.......
open UD
open stockGSR
import p28
change watever u want
save as
burn
gee i feel dumb now ... k lates
Old Aug 8, 2005 | 06:06 PM
93turbo16's Avatar
Default Re: (importnoodles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importnoodles &raquo;</TD></TR><TR><TD CLASS="quote">Okay well i got my ecu to work.... Guess it was my fault all along..
gee i feel dumb now ... k lates</TD></TR></TABLE>
its ok.
Old Aug 8, 2005 | 06:22 PM
hondaguyef's Avatar
Default Re: (93turbo16)
What was the problem? No ".bin" at the end of your saves or were you saving them into a different file?
Phil
Old Aug 8, 2005 | 06:50 PM
SOHCD16y8's Avatar
my prob is much diff, I am "using the ostrch on a P75, I hit upload in UD and it loads up bt it acts as though not chip is in there. Im using 1.7ost. And yes im using the right comm
Old Oct 4, 2005 | 03:39 PM
RudeLude's Avatar
ttt
JuicedUpRice
Nov 1, 2012 09:10 AM
xuecivic
Apr 2, 2010 12:02 PM
Flwr
Honda Civic (2006 - 2015)
21
Dec 18, 2007 03:25 PM
CivicSI1018
Aug 27, 2007 12:31 PM
