how to clean turbo
Old Aug 8, 2005 | 01:38 PM
hcivic99's Avatar
Default how to clean turbo
hey i was wondering how should i go about cleaning the compressor side of the turbo right now there is dirt and oil on it i was just wondering what i should use to clean it thanks
Old Aug 8, 2005 | 01:51 PM
EJ1 wilcox's Avatar
Default Re: how to clean turbo (hcivic99)
Is just the compressor cover dirty? If so, just take it off and use some parts cleaner and a toothbrush.
You could also take the nut, compressor wheel, and back plate off if you want to clean all that stuff too.
Old Aug 8, 2005 | 02:27 PM
hcivic99's Avatar
Default Re: how to clean turbo (EJ1 wilcox)
is there any specific torque that it needs to be torqued to when its put back on
Old Aug 8, 2005 | 02:51 PM
hcivic99's Avatar
well i took it off and i am seeing a black gasket?? it is dry and flakeing off does that need to be replaced? if so were can i get it
Old Aug 9, 2005 | 10:06 AM
yee SERIOUS's Avatar
i just use brake cleaner
Old Aug 9, 2005 | 10:37 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hcivic99 &raquo;</TD></TR><TR><TD CLASS="quote">well i took it off and i am seeing a black gasket?? it is dry and flakeing off does that need to be replaced? if so were can i get it </TD></TR></TABLE>
Yeah, if that gasket is dry and nasty it should be replaced.
Contact http://www.turbocity.com and I'm sure they will sell you one.
There are torque specs for the compressor cover and backplate but I can't remember them off the top of my head. You should be able to find them by searching around a bit.
tweensquirt
Feb 28, 2010 09:27 PM
averyvm
Jul 24, 2008 11:36 PM
integlspwr2k
May 18, 2006 06:24 PM
KiNG $h!t
Feb 4, 2005 01:41 PM
RACEPAK
Jul 20, 2004 01:55 PM
