map wire 4.6v? help
Old Aug 5, 2005 | 05:26 PM
love2xlr8integra's Avatar
Default map wire 4.6v? help
the signal wire going to my ecu when the map is unplugged is still reading 4.6v that's not right is it? the odd part is i am throwing a code 14 the idle air control valve code and i never had a problem with it till now
Modified by love2xlr8integra at 1:56 AM 8/8/2005
Old Aug 5, 2005 | 07:13 PM
bump
Old Aug 5, 2005 | 07:52 PM
what can be wrong?
Old Aug 5, 2005 | 07:58 PM
could it be my injectors
Old Aug 5, 2005 | 10:11 PM
dunkd's Avatar
are you sure it is wired correctly?
Old Aug 7, 2005 | 03:57 PM
hey, i was the one asking about the map reading 4.9v. yes i am sure i got it wired right. i even cut the wire 5 in. from the ecu and it still reads 4.0-4.4v. what could it be?
Old Aug 8, 2005 | 01:00 PM
JDMlyfestyle's Avatar
Bump for my boy. I couldnt figure it out either. I know it doesnt have anything to do with the injectors thats on a completely different circuit.
Old Aug 8, 2005 | 01:57 PM
hxtasy's Avatar
Default Re: (JDMlyfestyle)
maybe your checking the wrong wire, if you are still getting voltage from an INPUT than you have noise in your computer or your testing the wrong wire.
Old Aug 8, 2005 | 08:00 PM
it is not the worng wire. and where would the noise be coming from?
Old Aug 8, 2005 | 08:26 PM
Default Re: (love2xlr8integra)
Hey chris are you getting 4.6 V from D19?
D17 Signal wire
D19 5v power
D21 Ground
Old Aug 9, 2005 | 11:32 PM
with D17,D19,D21 cut about 6 in. fromthe ecu i get 4.7v on D17, 4.9v on D19
Old Aug 10, 2005 | 07:47 AM
tryed new ecu same thing
Old Aug 11, 2005 | 02:38 PM
bump
Old Aug 11, 2005 | 02:54 PM
I went and measured my stock voltage its.
Power 5v
Signal 0.01v
Ground. 0.00
Old Aug 11, 2005 | 03:38 PM
ramennoodles's Avatar
maybe your plugs got switch between iacv and map. not sure if there the same though
Old Aug 11, 2005 | 04:19 PM
nope he didnt ive seen the car and i wired up the map sensor correctly. car ran perfect in stock trim. then i did the map sensor for him and he's had nothing but problems with it. everything is done correctly.
Old Aug 12, 2005 | 08:31 AM
think its the hondata chips?
Old Aug 12, 2005 | 09:28 AM
Honestly i think you might have gotten a bad burn or something.
Old Aug 18, 2005 | 06:53 AM
went on up to the whip factory and we got everything going. it was because the dead end lead was up off
hotimportcrx
Nov 1, 2005 07:19 AM
love2xlr8integra
Aug 7, 2005 03:55 PM
Ski11z
Jul 15, 2004 08:36 AM
This One
Feb 2, 2003 04:20 AM
