Ok to run Fluidyne Radiator w/out Fans?
Here's a question, is it safe to run just the full size fluidyne radiator without any fans? The reason why I am asking is b/c space is limited in my engine compratment and I'd like to save as much space as possible. Thank You
This is for an Integra
Re: Ok to run Fluidyne Radiator w/out Fans? (DB8Sedan)
you need a fan when your idling for more than 10 minutes. you def should put a fan on your priority list.
Re: Ok to run Fluidyne Radiator w/out Fans? (pennhatch)
ive seen fans that are less then an inch thick....ive also seen fans that push air instead of pull and mount on the front of the radiator....you need a fan....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DB8Sedan »</TD></TR><TR><TD CLASS="quote">Here's a question, is it safe to run just the full size fluidyne radiator without any fans? The reason why I am asking is b/c space is limited in my engine compratment and I'd like to save as much space as possible. Thank You
This is for an Integra</TD></TR></TABLE>
if everyone else can do it, you can do it... you need a fan (slim fan preferred)
Re: Ok to run Fluidyne Radiator w/out Fans? (SHystrdyGSRtdy)
thanks. I already do have a flex lite fan but I was hoping a fan isn;t needed. guess i was wrong.
Thakns again
Thakns again
almostboostedgsr
07-26-2007 10:40 PM
