GReddy Profec Type S boost controller clarification
Old Aug 5, 2005 | 10:05 PM
poison's Avatar
Default GReddy Profec Type S boost controller clarification
Ok, we're tryin to hook up the boost controller to a boosted '97 LS with T3/T04e, 38mm TiAL with a 10 lb yellow spring.
We have the profec hooked up by the following:
Vacuum from the profec to the FPR
From the solenoid, we have NC hooked up to compressor housing
From the solenoid, we have COM hooked up to the top of the wastegate
Is this the correct installation?
We are attempting to only boost 5-7 lbs now, but I'm not 100% if it's hooked up.
With a 10lb spring, is the minimum psi he can run 10 psi? or can he boost lower than 10 psi?
Thanks.
Old Aug 5, 2005 | 10:06 PM
dunkd's Avatar
u can only boost as low as the spring
Old Aug 5, 2005 | 10:09 PM
poison's Avatar
Default Re: (dunkd)
Min 10 psi then huh?
Thanks for the clarification.
musclefella
Mar 26, 2006 06:21 PM
c61lude
Jan 19, 2006 04:34 PM
adseguy
Nov 12, 2005 09:26 AM
StolenTeg
Sep 8, 2005 04:17 PM
GettaluvR
Nov 2, 2002 10:38 AM
